| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53897 12/23/2005 7:48 PM | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I'm running a stock 46 3spd completely rebuild, new bearings, syncros etc. behind a warmed up 235 & 3.55 rear end. What can I expect from this trans. Will it last, or should I be looking for another one for replacement/parts or maybe a T5. My truck is a weekend driver and I'm not hard on it, I just don't know how long I should expect this trans to last, after all it is 60 years old. I don't want to change anything just to be changing it, it works fine now. Let me know what you think. Anyone have long term experence with this trans? Thanks George | | |
#53898 12/23/2005 8:59 PM | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | 46forme,
I don't know much about the 3 speed trans but I've just rebuilt the 4 speed in my 41. I expect it to outlast me and maybe even my son when it passes to him. The way that you intend using the truck yours should be the same. Just keep an eye on the oil level and change it when needed.
Cheers mate
Bob | | |
#53899 12/23/2005 9:41 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | What Mozzie said.
Those old transmissions are hard to kill even when you're trying.
Two of my aunts, my dad, and my uncle all learned to drive (or quite possibly grind coffee) on my truck, and the transmission still works great.
Heck, every once in a while, I grind the gears. When you don't drive it very often, it takes a little readustment when you get back into it. | | |
#53900 12/24/2005 3:27 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I'll second Brendan. I know of two failures with that tranny. First the soft spot is the first and reverse gear it slides on the second and third speed clutch. I blew the gear by popping the clutch 2-3 times consecutively. My first car 59 Chevy 235 and dumb a$$ kid. The other failure(s) was same gear, but in a 64 Impala with a factory 300 hp 327 and floor shift. Don't abuse it and it will last for years. Larry
I don't own a vehicle that isn't old enough to drink. | | |
