7 members (Gray_Ghost, Rusty Heaps, Brian Moore, 55shaker, Otto Skorzeny, Hotrod Lincoln, 1 invisible),
85
Mod | | | Forums66 Topics128,028 Posts1,055,414 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 24 New Guy | | New Guy Joined: Aug 2007 Posts: 24 | was looking for a E brake cable for a 1.5 ton. was looking at the 1/2 ton ones is this cable the same for all truck for a 1940 | | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | I dont think so, The large utility has a left and right cables to the rear backing plates. Gerard, do you have a shop manual? Dale | | | | | Joined: Aug 2007 Posts: 24 New Guy | | New Guy Joined: Aug 2007 Posts: 24 | Dale don't have a shop manual but have a number of books from that era. I realize now a shop manual will be handy. I have been getting a lot of conflicting answers about this truck some good and soon not so good. I order a manual from down South and even that leaves a lot of question unanswered. I guess my biggest problem is the size of the truck it is 1.5 ton and made here in Canada. Before I start work on this truck I want to makes sure I have all the right answers. Thanks for your input and I will be getting on to a shop manual soon Gerard | | | | | Joined: Dec 2007 Posts: 10 New Guy | | New Guy Joined: Dec 2007 Posts: 10 | Mine is also missing the e brake hardware. I can make all of my missing parts but the cables. If anyone knows a source, I'd appreciate it. I have found and old rusty mostly intact cable on a junk truck that I can copy if I have to have them made. | | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | Brake cables for .5 ton and 1.5 ton trucks are NOT the same. I have some NOS cables. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | You might want to get in touch with 3B on this board - he has a whole flock of larger trucks, and is a great source of info. | | | | | Joined: Dec 2003 Posts: 1,144 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,144 | got ebrake cables for my 38 1.5 ton from antique auto supply out of texas. about 40.00 each. | | |
