1 members (Samantha),
45
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 41 New Guy | | New Guy Joined: May 2009 Posts: 41 | Hey guys, I'm a newbie here, hope someone can help me out. I converted to 12 volts over the winter,everthing went pretty good, until I started her up. Starter now grinds, not everytime but maybe grind 3 times then turn key and starts. Winter before last the starter ws rebuilt and a new gear was installed,not one grind until 12volts. Is the 12 volt firing the startergear out too fast and just mashing into ring gear? I took it apart and cleaned up both gears with a dremel- there were burrs seemed to help but didn't cure it. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You need a new starter drive on the front of the starter. It has a one way clutch & is slipping internally. Get a new one. The rebuilts are not good.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you have a 12v starter of a 6v starter?
Do you have a 12v flywheel or a 6v flywheel?
| | | | | Joined: May 2009 Posts: 41 New Guy | | New Guy Joined: May 2009 Posts: 41 | I used a 55 bellhousing, flywheel and pressureplate to install a t5 tranny. Then realized my 6volt starter gears wouldn't work withthe flywheel.So at the time, not knowing any better I had the local auto electric guy modify my starter to install apropriate gear, i now know I could have just used a matching flywheel and starter. Anyway it is a 6volt starter with 12volt gear and 12volt flywheel, the same setup worked all last year-flawlessly,until the 12volt conversion. | | | | | Joined: May 2009 Posts: 41 New Guy | | New Guy Joined: May 2009 Posts: 41 | The reason I switched from original flywheel is that it was a powerglide | | | | | Joined: May 2009 Posts: 41 New Guy | | New Guy Joined: May 2009 Posts: 41 | | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Did you say you had matched the starter gear ratio to the # teeth on the flywheel ? Sounds like it does not engage correctly. Could be the " clutch " on the old starter is not working right. | | | | | Joined: May 2009 Posts: 41 New Guy | | New Guy Joined: May 2009 Posts: 41 | after cleaning up both gears with a dremel it works probably80% of the time I think I'll take my time and clean them really well and see how it behaves. | | |
