1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#538538 05/17/2009 1:44 PM
Hey guys, I'm a newbie here, hope someone can help me out. I converted to 12 volts over the winter,everthing went pretty good, until I started her up. Starter now grinds, not everytime but maybe grind 3 times then turn key and starts. Winter before last the starter ws rebuilt and a new gear was installed,not one grind until 12volts. Is the 12 volt firing the startergear out too fast and just mashing into ring gear? I took it apart and cleaned up both gears with a dremel- there were burrs seemed to help but didn't cure it.
Riding in the Passing Lane
You need a new starter drive on the front of the starter. It has a one way clutch & is slipping internally. Get a new one. The rebuilts are not good.
1972 Chevy c10 Cheyenne Super
Do you have a 12v starter of a 6v starter?
Do you have a 12v flywheel or a 6v flywheel?
I used a 55 bellhousing, flywheel and pressureplate to install a t5 tranny. Then realized my 6volt starter gears wouldn't work withthe flywheel.So at the time, not knowing any better I had the local auto electric guy modify my starter to install apropriate gear, i now know I could have just used a matching flywheel and starter. Anyway it is a 6volt starter with 12volt gear and 12volt flywheel, the same setup worked all last year-flawlessly,until the 12volt conversion.
The reason I switched from original flywheel is that it was a powerglide
no ideas?
Did you say you had matched the starter gear ratio to the # teeth on the flywheel ? Sounds like it does not engage correctly. Could be the " clutch " on the old starter is not working right.
1940 Chevy KC 1/2-Ton
after cleaning up both gears with a dremel it works probably80% of the time I think I'll take my time and clean them really well and see how it behaves.
