2 members (carbking, RLB),
157
Mod | | | Forums66 Topics128,080 Posts1,055,954 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 33 New Guy | | New Guy Joined: Jul 2007 Posts: 33 | I'm currently running a 4 speed saginaw in my 235 powered 54 3100, and I plan to install an S-10 T-5. I've read that an astro van uses an 11 inch 14 spline clutch that will work with the trans. Will this clutch work with my current bellhousing and pressure plate? Will I need a new pressure plate or another clutch that is different diameter? I believe I have a 10 inch clutch right now. Also from what I understand I will have to shorten the input shaft. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | go to tech tips and i will answer most of your questions. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Having done this install, my advise is check out the tech tips and do a search on the topic. My experience is make sure you cut the "snout" off the input shaft maybe 1/8" more than recommended, for that reason I had to shim my tranny/bellhousing. You will need to extend the length of the input shaft splines. If you go from 10" to 11" clutch, you will need the appropriate flywheel and pressure plate. I would think the clutch disc from S-10 or Camaro should work. | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | I will be checking in on this thread. I have a saginaw 3 speed and am looking at swapping it out for a T5. I found this thread for good info on the T5s used in f-body cars. Since I have bucket seats in my truck, Im okay with using a f-body trans which has the shifter further to the back. A f-body trans also requires no modifications. Are the 3 and 4 speed saginaw transmissions the same? For some reason I thought it had a 26 spline input shaft. | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | A good list of F-body t5 transmissions
Model Yr...Engine(s).Input....Speedo.......Ratio........Model # (BWA) 1983........2.8 V6......14............7..............T5E.78......1352-015 1983........2.5 L4......14............7..............T5H.73......1352-027 1983........5.0 V8......26............7..............T5G.73......1352-028 1984........2.5 L4......14............7..............T5K.72......1352-054 1984........2.8 V6......14............7..............T5E.78......1352-061 1984........5.0 V8......26............7..............T5G.73......1352-062 1984 1/2..LG4/LG9...26............7..............T5G.73......1352-070 1985........2.8 V6......14............7..............T5P.76......1352-071 1985........5.0 V8......26............7..............T5U.63......1352-072 1985........2.5 L4......14............7..............T5R.72......1352-083 1985........2.8 V6......14............7..............T5S.73......1352-084 1986........................26............7..............T5V.61......1352-150 1986........2.8 LB8.....14............7..............T5P.76......1352-156(aft) 1986........LG4/L69....26............7..............T5U.63......1352-157 1986........L4 LQ9......................7..............T5R.72......1352-158 1987........LB9 308....26............9..............T5U.63......1352-166 1987........LB9...........26............7..............T5U.73......1352-178 1987........V6............14............7...............T5P.76......1352-181 1987........LB9 308....26............9..............T5U.63......1352-182 1987........LB9...........26............7..............T5U.73......1352-183 1987........V8.............26............7..............T5U.72......1352-185 1988........B9 5.0L.....26............7..............T5U.73......1352-175(wc) 1988........LO3 5.0L...26............9..............T5U.63......1352-176(wc) 1988........LB8 V6......14............7..............T5P.76......1352-177(wc) 1992 1/2..LB9 5.0L...26............7..............T5U.73......1352-212(wc) 1992 1/2..LO3 5.0L...26............9..............T5U.63......1352-213(wc) 1992 1/2..2.8 V6.......14............7..............T5P.76......1352-214(wc) 1992 1/2..2.8 V6.......14............7..............T5P.76......1352-228(wc) 1989-92...LB9 5.0L...26............7..............T5U.73......1352-195(wc) 1989-92...LO3 5.0L...26............9..............T5U.63......1352-196(wc) 1989-92...LB8 V6......14............7..............T5P.76......1352-197(wc) 1993........3.4L V6.....26............7..............T5Z.72......1352-210(wc) | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | RAM Clutches has a good website that lists spline clutch diameter applications. | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I've been running a .72 BW T5 in my 54 truck for about 8000 miles.....used an 83-84 Firebird clutch disc with the stock pressure plate and T.O. bearing. I've documented the T5 mods in my Webshots "Shoebox" album and offered some tips that will save you a bunch of time and energy.
There are basically 2 common S10 T5's...the .72 OD with a 3.76 1st gear and a .86 OD with a 4.03 1st gear. The .72/3.76 runs through 1st gear very quickly, even with a 3.42 R&P......the 4.03 even quicker with a 3.08 R&P. You might want to consider the Camaro/Firebird T5 with a 2.95 1st gear and a .63 OD. The gear spread is much tighter and coupled with a 3.73 R&P should be slick in an AD truck. I'm using it in my next project build. Of course, there's always a hoop to jump through...the Camaro/Firebird boxes have a shifter mounted way back on the tailshaft. If you check out "Hybrid T5's" you'll see the conversion to a forward mount shifter. The only hitch to the conversion is using a cobalt drill bit to make a dimple in the mainshaft to relocate the mechanical speedo gear.
Upgrading to the T5 transmission is in my opinion, the best way to get your truck up to modern highway speeds. The .72 T5 with a 3.42 lets you cruise comfortably at 70 mph at 2000 rpms and you can drop down to 45 mph and accelerate with traffic with no downshift. Combine the transmission upgrade with some front discs, sway bars, gas shocks and some radials and you'll transform your truck into a great cruiser while still maintaining the "stock" look. Hope this helps.
Dave | | | | | Joined: Mar 2009 Posts: 29 New Guy | | New Guy Joined: Mar 2009 Posts: 29 | Your pictures are great!!! finally I think I have a good idea of what I'm going to do with my build. I did read on one of the pictures that you cut 1 3/8 off of the throughout bearing shaft. Thats the first I've heard of doing that, is that the peice that holds the front bearing? | | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I would suggest that you tailor your T5 to the same measurements as your current Saginaw measurements. That way, you know for sure that the T5 will mate with your bellhousing. Mine just happened to be the measurements that duplicated the sm420 that came in my truck.
The T5 T.O. bearing retainer shaft is secured with 4 bolts....remove it from the transmission to make your cuts. Be sure to chamfer (gently) the ends where you cut them off. Also, make sure you slide the clutch disc PAST the end of the splines. If you ASSUME you've got them dressed down sufficiently and install the transmission, you may discover that your disc will not fully release. I found this out the hard way!! While you've got the T.O retainer shaft off.....replace the little seal that keeps the transmission fluid from contaminating your clutch pack. Ditto on the tailshaft seal. Also, the short bed S10 driveshaft is nearly perfect length.
I feel obligated to tell you that adding the T5 and getting your ride up to highway speeds is going to involve more than just bolting on the transmission. While you're developing your plan, be sure to take into consideration brakes, sway bars, snugging up the straight axle and installing upgraded tie rod ends. You'll find that the straight axle truck will handle the higher highway speeds with ease.....and the little 235 will push her along at 70 mph with ease and at 80mph you'll still have throttle left. Aside from the harsher ride of the straight axle, you'll discover that manual steering gives you ample feedback and that manual disc/drums will do the job with less potential for lock-ups. The key to building a good running truck or streetrod is to do your homework....ask plenty of questions and don't get caught up in just throwing money into your ride. You'll find that keeping the 235 and making some subtle upgrades will pay off when you're cruising down the open road or at the car shows. The Old Chevys have a loyal following and you'll get a chance to meet some nice fellow "Stovebolters" who'll share their own adventurers.
Dave | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | I have a T5 hybrid, camaro guts in an S10/15/sonoma truck housing, 26 spline, corvette clutch and PP. i have a 3.40 12 bolt rear e/w 2.75'' brakes and a 292 high torque motor. front end rebuilt & upgraded to 6 lug disc e/w power master. having a more modern motor i did not have to cut the T5 shaft, but as mentioned you do w/ a 235. here are the calc's for various set-up, tire sizes and rear ratios. a quick change shifter can be made ... see tech tips stovebolt http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=584226-R1-050-23A.jpghttp://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=DSC00367.jpghttp://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=4472530-R1-029-13.jpghttp://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=15.jpghttp://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=17.jpg1951 Delux Chevrolet 5 Window Pickup Tire Diameter : 28 inches Rear Gear Ratio 2: 3.40:1 MPH @ 3:40 ring & pinionRPM 1st 2nd 3rd 4th 5th 6th 1000 8 12 18 24 32 0 1500 12 18 26 35 48 0 2000 16 24 35 47 64 0 2500 20 30 44 59 79 0 3000 24 36 53 71 95 0 3500 28 42 61 82 111 0 4000 32 48 70 94 127 0 4500 36 55 79 106 143 0 5000 40 61 88 118 159 0 5500 44 67 97 129 175 0 6000 48 73 105 141 191 0 6500 52 79 114 153 207 0 7000 56 85 123 165 222 0 7500 60 91 132 176 238 0 8000 64 97 140 188 254 0 MPH @ 3:43 ring & pinionRPM 1st 2nd 3rd 4th 5th 6th 1000 8 12 18 24 32 0 1500 12 18 27 36 48 0 2000 16 24 35 47 64 0 2500 20 31 44 59 80 0 3000 24 37 53 71 96 0 3500 28 43 62 83 112 0 4000 32 49 71 95 128 0 4500 36 55 80 107 144 0 5000 40 61 89 119 160 0 5500 44 67 97 131 176 0 1951 Delux Chevrolet 5 Window Pickup Tire Diameter : 28 inchesMPH @ 3:73 ring & pinionRPM 1st 2nd 3rd 4th 5th 6th 1000 7 11 16 22 29 0 1500 11 17 24 33 44 0 2000 15 22 33 44 59 0 2500 18 28 41 55 74 0 3000 22 34 49 65 88 0 3500 26 39 57 76 103 0 4000 30 45 65 87 118 0 4500 33 51 73 98 133 0 5000 37 56 81 109 147 0 5500 41 62 90 120 162 0 MPH @ 4:11 ring & pinionRPM 1st 2nd 3rd 4th 5th 6th 1000 7 10 15 20 27 0 1500 10 15 22 30 40 0 2000 13 20 30 40 54 0 2500 17 26 37 50 67 0 3000 20 31 44 59 80 0 3500 23 36 52 69 94 0 4000 27 41 59 79 107 0 4500 30 46 67 89 120 0 5000 34 51 74 99 134 0 5500 37 56 81 109 147 0 as dave [above] says it a whole package deal http://www.stovebolt.com/techtips/draglink_adjustable.htmlhttp://www.stovebolt.com/techtips/shifter/index.html
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
