4 members (Shade Baby, 1955 1 Series, 55shaker, Wally / Montana), 119 guests, and 4 robots.
Topics128,139
Posts1,056,448
Members48,441
#53822 12/21/2005 4:01 AM
I am in the middle of swapping the original 4 speed tranny in my '63 C-10 to a T-5 out of a '91 S-10 and have reached my first head scratching holdup. Anyone converted to a hydraulic clutch before? Any pointers for mounting the master cylinder?
Daily Driver 63 C-10 LWB Fleetside
#53823 12/21/2005 4:35 AM
Take a look at a 60-62 V8 pickup setup. The stock clutch master cylinder might bolt right in, but you will need a V8 bellhousing from the same years.
Why would you have to change the clutch to hydraulic?
#53824 12/21/2005 4:54 AM
The price was right on the new trans (free) but it has an integral bell housing so I can't keep the original setup which means I have to reconfigure the clutch linkage...hydraulic seems easier since the slave cylinder is prominant feature on the new trans.
#53825 12/21/2005 6:00 AM
The 60-62 clutch master cylinder may work if the brake master cylinder didn't change from 62 to 63.
#53826 12/21/2005 6:29 AM
Thanks. I'll check it out.
#53827 12/21/2005 6:13 PM
Be sure and check the bolt pattern on your T5 transmission bellhousing. If it is from a 4 cylinder it won't match your 1963 motor. It needs to be from a 4.3 V6 or V8 to bolt to your engine. If your bellhousing was detachable the transmission would bolt to your original bellhousing.
A 1965 Chevy C-60 2-Ton Flatbed
A 1953 Chevy 1/2-Ton
A 1949 Chevy Business Coupe
