7 members (baldeagle, walter74, 51sub, TexasA&M48Truck, JW51, Hotrod Lincoln, 1 invisible),
39
Mod | | | Forums66 Topics128,005 Posts1,055,255 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 4 New Guy | | New Guy Joined: May 2009 Posts: 4 | I like to know what company makes the best fitting highest quality patch panels. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | As far as I know none of the patch panels fit right into place. They are nothing more than a good start. All take work to fit into the area you have cut out.
As for high quality, what makes a patch panel high quality?
And you probably can't buy them from the company that makes them. You have to buy from retailers. | | | | | Joined: Dec 2006 Posts: 443 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 443 | Any patch panel is going to require a little craftsmanship to do a good job. 1957 Chevrolet 1/2-ton Stepside LB in the Gallery My Photobucket shots The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself." - John Stuart Mill (1806 - 1873) | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Someone should keep track of how many times this question gets asked in a year. | | | | | Joined: Feb 2008 Posts: 829 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 829 | We could replace the FAQ tab with a catalog of them.  | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | And, another problem is that any vendor who has a good patch panel at one time cannot be sure that the next set they buy will also be good.
| | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Took my '58 Chevy into a guy to fix a litle spot around the headlamp area and he ground it off to find someone had riveted in a piece.....some body guy huh??? Anyone in here know where to find a patch panel for the LF fender headlamp area?
Thanks, Steve in Idaho
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no patches available for the 58/9 headlight area, need to fab it up yourself or find some used fenders to cut pieces from Goodmark makes good patches, usually available from your FLAPS, like NAPA [in Canada same things available from Cross Canada thru NAPA] Bill | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | You could ask metalman if he does or will make them for you...joe Ray Stanley Wheelwright Restorations 92 Pine Street Wheelwright, MA 01904 1-413-477-6467 [email protected] | | | | | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | Good quality? Aren't they all made overseas? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no they're not all made overseas, and even the ones that are have good and bad, depends on who contracted the piece
Bill | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | They all seem like a perfect bargain when you start thinking of how much time and effort you'd have to spend to actually MAKE the same part from a piece of sheetmetal. I've spent more than my fair share of money and time replacing cab panels and I'd have to say that overall the quality is good. Most are better and some are worse (inner-to-outer cowls) but all are usable if you have a working knowledge of sheetmetal.
It's been my observation that guys with mechanical skills dismiss sheetmetal as something not requiring any special skills and quickly find themselves in trouble that is, of course, the result of "crappy Chinese parts". Sheetmetal requires a unique set of work skills so if you've never done it before expect to have problems. If you have experience with sheetmetal I think you'll find them to be an overall good value. | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Good quality? Aren't they all made overseas? I personally have never bought anything from Ray, BUT those who have bought sheetmetal from him have said it is top quality stuff & he makes it himself here in the good O'USA. HERE's he's ebay page. And HERE's his webpage. Ray isn't the only person out there that does this. You just have to pick & choose who you want to spend your $$$$ with...Joe | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i bought a pair of cab corners from jim carter for my 49.they did not have the lip for the door opening.i was at a swapmeet and a guy in a van from tennesee was selling truck parts he had cab corners that included the lip.my drivers side had a little rust close to the opening .so for 30.00 i bought that one and sent the other one i had to JDL. there is a difference........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
