| | | Forums66 Topics128,049 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53779 12/19/2005 8:43 PM | Joined: Jun 2000 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2000 Posts: 50 | If you want to see one there is a roots type blower manifold for a 235 on e-bay, item # 8023718693. Too rich for my blood but an interesting concept. Just supposing someone wanted to supercharge a 235 what would be the weak link in the motor design... the bottom end? Looking at certain OEM specs, Jackson Blowers for instance, it looks like their roots-type blowers provide significant boost at low RPM's, rather than centrifugal blowers that don't even start to work until you hit 3500 RPM plus.... just having a "Frankenstein" moment regarding my truck! :mad:
1951 Chevrolet 3100 AD Pickup
#53780 12/19/2005 9:02 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | JNash,
I think you hit the nail on the head...the bottom end! Main bearings... to few and too small. Two pounds of boost wouldn't kill the motor, and you would get rave reviews.
Stuart | | |
#53781 12/22/2005 12:06 AM | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | JNASH, the weakest link in the lower end of a 235 is the rod bolts. I know from experiance that they are weak and have the broken rods and bad blocks to support it. Change the stock rod bolts the ones for the 454 big block and drive with less worry about dropping a rod through the side of the block. Just my .02 worth.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
#53782 12/22/2005 5:05 PM | Joined: Jun 2000 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2000 Posts: 50 | Gents - After searching "superchargers" I found many discussions on forced injection, very interesting reading. One of the threads had a link to a photo of bottom end strengthening mods, like adding a saddle over the bearing blocks, etc. Can't find it again though ..... Obviously with enough money you can do anything but I think a very low boost roots/carb set up that assists lower RPM ranges would work and be alot of fun to show! Regards,
