3 members (Nick in Manitou, UtahYork, Bill Hanlon), 78 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#537102 05/13/2009 12:35 AM
Got an alternator question, on of all things, a Dodge D500 fire truck. All I need to know is if I can replace a stock alternator with 1 field terminal, with a newer rebuilt alternator with 2 field terminals. If so, how do I wire the stupid thing.
Thanks Electrical Gurus
(I promise when I get this thing going I'll go back to my Loadmaster and my '67 C-10.) grin
Keith
If it were easy they'd have grade schoolers doing it!
3B Offline
Hy Pakrat48, it sounds like both alternators must have external regulators, you should be able to find a wiring diagram at the manufacturers website. Or give us a lot more info please.
The 2-terminal alternator has what's called an "isolated field" system. There is no internal ground for the alternator field coil. It you choose to use the 2-terminal alternator, just ground one of the field terminals (doesn't matter which one) and run the original field wire from your existing regulator to the remaining field terminal.
The factory wiring for the isolated field alternator ran 12 volts to one field terminal, and put the regulator on the ground side. That one takes a different regulator so the simplest way is to create an external ground for the replacement alternator.
Thanks Jerry, that's what I thought but wasn't sure.
Back to the Chevys!!!
Keith
Are you sure that the new alternator is externally regulated?
If it has an internal regulator you may have a field and a sensing connection as well as the batt. terminal.
Stuart.
