| | | Forums66 Topics128,052 Posts1,055,773 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Got an alternator question, on of all things, a Dodge D500 fire truck. All I need to know is if I can replace a stock alternator with 1 field terminal, with a newer rebuilt alternator with 2 field terminals. If so, how do I wire the stupid thing. Thanks Electrical Gurus (I promise when I get this thing going I'll go back to my Loadmaster and my '67 C-10.)
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Pakrat48, it sounds like both alternators must have external regulators, you should be able to find a wiring diagram at the manufacturers website. Or give us a lot more info please. | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | The 2-terminal alternator has what's called an "isolated field" system. There is no internal ground for the alternator field coil. It you choose to use the 2-terminal alternator, just ground one of the field terminals (doesn't matter which one) and run the original field wire from your existing regulator to the remaining field terminal.
The factory wiring for the isolated field alternator ran 12 volts to one field terminal, and put the regulator on the ground side. That one takes a different regulator so the simplest way is to create an external ground for the replacement alternator. Jerry
| | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Thanks Jerry, that's what I thought but wasn't sure. Back to the Chevys!!!
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | Are you sure that the new alternator is externally regulated?
If it has an internal regulator you may have a field and a sensing connection as well as the batt. terminal.
Stuart. | | |
