| | | Forums66 Topics128,041 Posts1,055,483 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53760 12/19/2005 2:38 AM | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | I have a 50 3800 and a 48 thriftmaster. I am having a little trouble figuring out what engines they have in them. The 50 3800 engine has bolts down the center of the valve cover and an oil bath air cleaner. The 48 thriftmaster has 4 bolts holding the valve cover down around its lip. I do not know whether these are the original engines or not. Any help would be greatly appreciated. | | |
#53761 12/19/2005 3:02 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | The 50 may have the correct engine, but engines and heads with the four bolt valve covers came out in 1954. | | |
#53762 12/19/2005 3:15 AM | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | Thanks Baldy. Also, did the 47-53 1-tons have the same engines(216ci) as the 1/2 tons? What are some ways I can tell what year/displacement the 48's engine is? Are there any serial #'s on the engines that tell this information, and where are they located? | | |
#53763 12/19/2005 4:15 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You need to check the casting numbers to know for sure what you have. Check inliners.org for casting numbers.
The engine serial number might tell you, but since these trucks were often titled using the engine number instead of the body serial number, sometimes the engine serial number has been changed to match the original when the motor is replaced.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#53764 12/19/2005 5:06 PM | Joined: Apr 2004 Posts: 703 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 703 | High School Hauler.
You're about going to have to look at casting #'s and such to determine what you've got. Alot of the early 1+tons had a 235 that visually looked identical to the 216.
From what I understand, they shared all parts, valve and side covers etc, but had a different stroke, making it a 235 instead of a 216.
In my recently purchased 52, I'm running an early 235 out of a 48 2-ton truck. Again, visually, you'd never know a difference between it and the 216 that's in my 46.
By the way, the #'s you're looking for, should be on the pad behind the distributor, or cast into the block along the top of the starter. Hope that helps. | | |
#53765 12/19/2005 5:18 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Jed is correct, 216 and EARLY 235s look exactly the same, heads even interchange. I'm running one of these early motors in a 47 coupe. Check the passenger side of the pan, mine had '235' stamped into the side. Only real trouble with the early 235 High Torques is that the compression was very low.
Also, the motor with the 4 bolts around the valve cover would be 54 or later. | | |
#53766 12/19/2005 5:26 PM | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | Thanks for the help. The trucks are at our shop in town. I'm going down there today if I get a chance. I'll check for the serial #'s while I'm down there. Again, thank you. | | |
#53767 12/27/2005 8:58 PM | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | I just got around to checking the numbers on the '48 thriftmaster. The pad behind the distributor has what I believe to be "FI2I6A" stamped into it. I checked inliners and couldn't where these numbers were listed. | | |
#53768 12/27/2005 9:24 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I wouldn't get to concerned about the 'stamped' numbers, main thing is the block casting number which will give you the basic info. Stamped number will refer to externals like trany etc. | | |
#53769 12/27/2005 10:40 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | that isn't the type of number listed at inliners - they have casting numbers - cast right into the side of the block and top [usually] of the head - here\'s another site for some casting number info - you need to get the casting numbers to really identify it like Jim sez, stamped/engraved numbers are sometimes meaningless - but the stamped numbers from the factory I think, for all the pre 54 engines had an identifier that started w/ 3 letters, then had the size #'s, later ones a single letter, then 2 numbers that indicated the year - that looks like some kinda combination of older and newer numbering, and I'd say the F= built at Flint plant, 216= a 216, the I or A would indicate the trans Bill | | |
#53770 12/28/2005 8:10 AM | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | For the serial F1216A:
F=Flint 1216=engine build date=December 16 A=regular production 235 passenger car engine (w/3 speed), '57-'62.
The A suffix was also used for the '63 & '64 230 car engines. The year will have to be determined from the block casting date.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
#53771 01/01/2006 1:00 AM | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | I found the number cast into the head. It is either "844845" or "B44845". I couldn't tell whether the first number was an 8 or a B because of the rust. The number "850" is cast on the head just below the number mentioned above. I can't tell what the number above the starter is, I'll have to pull the starter off to see it. Thanks for the help. | | |
#53772 01/01/2006 8:23 AM | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | I assume that number (B44845) is on the right side of the head. That's probably two separate numbers cast close together. B44 would be the casting date code. The actual head casting number should be on top of the head on the left side, next to the valve cover flange.
#53773 01/01/2006 8:55 AM | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I tried looking up your casting numbers. Most head casting numbers are seven digits. I know on my 261, the casting numbers are on top of the head,on the drivers side. Hope this helps !!! 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
