| | | Forums66 Topics128,024 Posts1,055,392 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53757 12/19/2005 2:26 AM | Joined: Dec 2005 Posts: 1 Junior Member | | Junior Member Joined: Dec 2005 Posts: 1 | the clutch that came out had 3 fingers that the bearing presses against to do its job and the new supplied one has a dozen or so. Am I good to go as long as it all bolts up fine like it does?
doug
#53758 12/19/2005 3:28 AM | Joined: Mar 2005 Posts: 75 Member | | Member Joined: Mar 2005 Posts: 75 | They both will do the job. the three finger job is a better clutch. the one with all of the fingers is a diaphragm type and the three finger is a bore and beck type. I have the diaphragm type from auto zone that has lasted for a long time and I'm hard on them. the only thing that may be different is the throw out bearing there are two size's a short and a long to make the clutch work right you will needed to match it up.
super250six | | |
#53759 12/20/2005 12:24 AM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I like the dia. type better.It is smoother & softer. They are the replacement for the finger type. Just be shure you use the correct T.O. brg. like Super six says. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
