6 members (Jon G, klhansen, dt235sd, Tim Canfield, Oswald, 1 invisible), 92 guests, and 2 robots.
Topics128,035
Posts1,055,445
Members48,422
#53757 12/19/2005 2:26 AM
Junior Member
Junior Member
the clutch that came out had 3 fingers that the bearing presses against to do its job and the new supplied one has a dozen or so. Am I good to go as long as it all bolts up fine like it does?
doug
#53758 12/19/2005 3:28 AM
They both will do the job. the three finger job is a better clutch. the one with all of the fingers is a diaphragm type and the three finger is a bore and beck type. I have the diaphragm type from auto zone that has lasted for a long time and I'm hard on them. the only thing that may be different is the throw out bearing there are two size's a short and a long to make the clutch work right you will needed to match it up.
super250six
#53759 12/20/2005 12:24 AM
Riding in the Passing Lane
I like the dia. type better.It is smoother & softer. They are the replacement for the finger type. Just be shure you use the correct T.O. brg. like Super six says.
1972 Chevy c10 Cheyenne Super
