7 members (UtahYork, cmayna, Mike B, tclederman, dt235sd, Otto Skorzeny, 1 invisible),
210
Mod | | | Forums66 Topics128,271 Posts1,058,415 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53749 12/18/2005 7:53 AM | Joined: Aug 2005 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 51 | To remove my clutch in my '46 GMC I had to drop the tranny (4spd.) Since it is out aside from rebuilding it what is the best way to clean all the years of old oil sludge, sediment and grime out of it? I thought maybe remove the shift tower with it drained and use a varsol sprayer to clean it out then new oil and install. Also by removing the shift tower am I creating any new problems that should be dealt with later. As always any advice is greatly appreciated.
Scott | | |
#53750 12/18/2005 7:03 PM | Joined: Dec 2004 Posts: 425 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 425 | Put all new gaskets in it while you have it out too. I have a 49 4 speed (not sure if it's the same as 46) but anyway, i took mine apart and washed it in my parts washer, then used the blow gun to blow it dry and get all remaining particles off. Without a parts washer, i'd use a pressure washer on it. Taking just the shift tower off isn't a big deal at all- like i said before you should put all new gaskets in it anyway... they're cheap. | | |
#53751 12/18/2005 10:37 PM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | Kerosene its what the old timers used to clean parts | | |
#53752 12/19/2005 12:26 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I flushed mine out with kerosene. It will get the worst of the gunk out. One problem that comes from cleaning out too much gunk is that it creates leaks. As long as the gunk is stuck to the housing it won't be causing any problems.
Fred 52 3600 69 C-10
#53753 12/19/2005 1:22 AM | Joined: Aug 2005 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 51 | Do I need to actually take the whole unit apart or just fill it with kerosene and swish it around then drain it? and fill it with oil again.
Scott | | |
#53754 12/20/2005 12:16 PM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | Just fill it with kerosene and swish it aorun and spin the tranny with it n gear to get it circulated then let it sit for a while and drain | | |
