| | | Forums66 Topics128,192 Posts1,057,355 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 321 Shop Shark | | Shop Shark Joined: May 2007 Posts: 321 | Hey guys, I noticed that my new suburban has some interesting things that I haven't seen before on 3100's. I think I have a factory installed sway bar up front? Also, in the rear, I have springs over the rear axle (looks like helper springs) as well as the typical ones under the axle. Does anybody put the helper springs back in the rear? Is this factory? I guess I need to poke through my assembly manual tonight when I get home. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the sway bar was standard on panels and burbs all years, the auxilary spring pack was an option to increase GVW rating from 4000# with base 15" wheels to 4600# with the 16's - up to you if you want them, they won't make any difference to the ride unless the truck is heavily loaded
Bill | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1949 3100 Advance-Design Suburban - 1/2 ton
An optional 10-leaf Heavy Duty Rear Spring set was available in 1954 (but is not listed in 1949). In 1954, the 10-leaf set was an RPO for the 8-leaf spring set that was standard from 47-55. 16" wheels were standard in all A-D years on Suburbans (15" wheels were optional).
The "anti-sway" bar (a better name) was called a "stabilizer" by GM and was standard on the Suburban and the 1/2 ton Panel (the stabilizer might not have been installed on the 1-ton panel, however). The style of this assembly changed in 1951. Jim Carter sells both styles of bushing sets.
Of course, someone might have installed helper springs.
Tim | | | | | Joined: May 2007 Posts: 321 Shop Shark | | Shop Shark Joined: May 2007 Posts: 321 | Thanks guys. I think I'll for sure leave the anti sway bar, but may drop the rear leafs. What an interesting option though! | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | My 49 has the sway bar.
Weeds | | | | | Joined: Nov 2001 Posts: 1,522 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,522 | My 54 and 52 also have the anti-sway bars. | | |
