5 members (Charles in CA, klhansen, FishinToms53, Hanks custodian, 5 Window 9434), 53 guests, and 0 robots.
Topics128,049
Posts1,055,634
#536343 05/10/2009 3:10 AM
Apprentice
Apprentice
Hello all, It has been awhile since I have been on, do we have an engine decoder page on the stovebolt page. I need parts to rebuild my starter and I would like to identify the year of my motor. The number stamped on the flat right behind the distributor is F0523B.
Thanks for anytime you can give me on this,
Ranger
Because of God's Grace,
Ranger Ric
Micah 6:8
Remember if you are driving one of those other things.....stop it!
visit our homepage for pictures of my trucks and our dogs. http://www.rainydaysmastiffs.com
1957, Flint plant, Passenger car w/ automatic.
Bill Burmeister
Apprentice
Apprentice
Thank you can you tell me where you found that at. I went to several web sites and could not find anything that even resembled my number. Thanks again for your time. RR
Ranger Ric
Micah 6:8
The Catalog of Chevy Truck ID Numbers 1946-1972, published by Cars & Parts. Not sure if it's still in print, though.
Bill Burmeister
Thank you, Tim. This is exactly what I was looking for to ID my 52 216 that I took out of a car.
The only thing I do not understand is following the last 4 digits which designated the sequence number from assembly there is a letter and number. What is that? Does anyone know?
TIA
Dennis
Dennis,
Post your code - maybe someone can help.
Tim
1952 car engine serial numbers
1952 truck engine serial numbers
Help me out here please, I'm a little cornfused (not to worry, nothing new). Dennis' engine no. (F0523B) was identified as a '57. Where is the year code in that no.? When they went to this format (apparently sometime in 1957) they continued it for several years so wouldn't that same number have been used in '58, '59 and possibly later? Don't we need to look at the casting numbers on this one to pin the year down?
Ranger,
I believe this is the decoder site you asked about.
http://www.stovebolt.com/techtips/vin/vinbuster.html
Harold smile
Harold
You have a valid point. I just double checked the book, and it does list a B code engine up to at least '60 (my book doesn't go past '60 for passenger engines), so checking the date code near the starter might be in order. The B code comes up the same for all years, 235 W/Powerglide.
Bill Burmeister
Very good point, waldo53.
The casting-date codes (block and head) are helpful. But, a combination of casting-date codes, block and head casting codes, and engine serial numbers are the best way to make an identification.
Does anyone know if 216 head and block codes are in the same locations as these codes found on later 235 and 261 engines?
If anyone is willing/able to send me photos of all the 216 codes, I be please to give them credit in a web-page that displays photos of all the 216 codes. A photo of both sides of the block would also be helpful - the oil distributor cover/plate on the manifold side of the block, in particular.
Tim
