| | | Forums66 Topics128,131 Posts1,056,723 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | i just put in new front cylinders,main cylinder and profesionaly rebuilt hydrovac. ive put in a quart of fluid in already and am only getting a little pressure back in the pedal to push it back up about a quarter of the way up.Does anyone know what im doing wrong?do i just keep on filling with fluid?Is the hydrovac supposed to fill with lots of oil? Whats going on here? Thanks
| | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | | | | | | Joined: Oct 2007 Posts: 568 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 568 | Adjust you're brakes with the adjusters. Jack up one wheel or set of wheels just off the ground. When you get a slight drag while spinning the wheels, try bleeding them again. When I did mine, they where a bit spongy and I felt as though I needed to double pump them to make sure I had enough brake. They got better after some use. Adjust them and drive the truck slowly around in the yard and then readjust the adjusters. Make sure there is a little drag on the drums. It worked for me. By the way, I bypassed my Hydrovac for the time being till I can get it rebuilt. I don't know if that will make for a different outcome for ya. | | | | | Joined: Apr 2009 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 121 | thanks for the manual! That things great! Im gunna try bleeding the other valve that i missed on the hydrovac and hopefully thats my problem.Thanks again | | |
