5 members (Otto Skorzeny, Shade Baby, Wayne67vert, Phak1, texczech), 142 guests, and 2 robots.
Topics128,136
Posts1,056,428
Members48,441
#5357 09/21/2003 3:01 AM
k10
Offline
Does anyone happen to have a Napa or other number for a fan belt for a GMC 228 w/ original Generator? The cover over the motor mount means that it should be thin-say 7/8" or less.
I pulled my radiator out of the '45 last week fully expecting to have it recored. Turns out it's not original, but it looks like maybe from a 3/4 ton. PO had drilled new holes in the mounting flange about an inch higher than the original raditor sat. Took it to a local radiator guy, he pressure tested it to 18psi-no leaks. Cleaned it, and he got a flow rate of 17 gals per minute. He said no new core wasn't going to touch that. $48 bucks please, Thank you very much. Looks like I may be stuck with a flex lower hose- the lower end points up at a 45. If it was straight the Chevy hose would fit. New water pump is on and a thermostat! PO didn't believe in them apparently. Now all I need is a belt that fits. grin
#5358 09/21/2003 7:21 AM
I looked on the belt on my 228 and the only thing I can get off of it is
B106 --- 385 Made in U.S.A. 15435 ------- 089
#5359 09/21/2003 3:30 PM
Bondo Artiste
Bondo Artiste
Howdy K10!! Check www.oldgmctrucks.com
He has a section of part numbers used for belts and such from Napa Auto Parts stores.
I hope this helps!!
~ Phillip
#5360 09/21/2003 6:49 PM
k10
Offline
It does, but I have the larger pulley. I.e. 7/8"
#5361 09/21/2003 7:46 PM
oops!
missed that part the first time. the pulleys on this 228 are narrow.
Just wanted to let you know so you didn`t try to cross that number with one for the wide belt.
Is there any way you can take yours off and take it into NAPA to match it up?
#5362 09/21/2003 9:41 PM
Before NAPA closed it's Morgan Hill Distribution Center, I was able to get a 7/8" belt for the '51 GMC 248. Sadly, I gave the new owner the old belt and sleeve, so I'm not sure about the #; but I think (this is the dangerous part wink ) it's #11133, but I'm probably wrong. I know I only paid ten bucks for it back in '98 eek .
*** GMC ***
#5363 09/28/2003 7:57 PM
I've got the same problem....
My 50 248 powered 300 GMC had the narrow belt water pump. Well, when I fixed it, I put the "correct" one, but now I have to find a belt. I'm just reusing the old narrow belt, so the thing squeeks when you rev it up.....
Napa Web page actually has a search for parts.....and part numbers
1948 Dodge 2 ton
1950 GMC 1 1/2 ton
1952 GMC 3/4 ton
#5364 09/29/2003 12:47 AM
k10
Offline
I believe I have found one. I will post it here in a week or so, after I put it on and try it out. I did have one from Napa that looked perfecr compared to the original, but I just couldn't get it mounted due to the motor mount. We'll see.
