Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Woogeroo, klhansen, jay d, 1 invisible), 130 guests, and 2 robots.
Topics128,288
Posts1,058,577
Members48,492
#536210 05/09/2009 12:52 PM
My truck will fun for a few minutes fine, then start sputtering. If I let it idle for a bit, it will run for a few minutes again. The fuel filter is clean, I tried a new fuel pump and the points are clean and adjusted properly. What could be doing this? Can it be the coil or condenser?
Any ideas?
Andy
Will it rev up?
Drew
It will rev and run fine for awhile, then sputter and only idle.
I would just do the basic stuff first. Check for loose carb and distributor mounting bolts and for vacuum leaks. Make sure nothing is loose inside the distributor and it's holding its point gap. Make sure the vacuum advance is working properly, although it sounds like it is. Make sure there is no fuel line clogging as demand increases on reving. Just because the filter looks good doesn't mean something isn't plugging it somewhere else with tank sludge.
Drew
I figured it out today. Bad coil wire. I put an old one on it and away she went!
Andy
