| | | Forums66 Topics128,022 Posts1,055,362 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 47 | Anybody know what the original carb is for a 61 Apache? The original carb was replaced with whatever the previous owner could find. He plugged whatever fittings weren't being used and even put some kind of putty at the fuel line fitting so it wouldn't leak! | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | Rochester B. You can occasionally find them NOS on eBay. While you're there, look for a maintenance manual too. It sounds like you need one. | | | | | Joined: Nov 2008 Posts: 57 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 57 | Concur with K10, Rochester B is the original one for the 235. I sold mine and went with a 2bbl from stovebolt engine co and it not only fit like a charm, it works like a champ. I think it was $200 with linkage kit. | | | | | Joined: May 2009 Posts: 19 New Guy | | New Guy Joined: May 2009 Posts: 19 | Yep Rochester B You can buy a new /rebuilt one from Holley the Part number is 64-7128. Covers 1960-1962 235 Just put one on a 60 model.
| | | | | Joined: May 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2009 Posts: 47 | Nomad, Is this the 2bbl carb you're refering to? stovebolt engine co | | |
