5 members (delwrench, GrandpasJimmy, KEVINSKI, greenie-reddy, 78buckshot), 99 guests, and 3 robots.
Topics128,193
Posts1,057,249
Members48,466
#535368 05/06/2009 6:52 PM
I am building a 46 1/2 ton but need help with what bracket to use with a powerbrake booster and leave it under the floor. You can buy them for 47 and newer but not for 46's. any one have suggestions. Please help.
I wonder if you could buy the later one and fabricate it to fit your truck.
~Jim
the one on my 46 is the one for the 47-53 and fits fine. I have a small block and th350 trans and not the original 6. Not sure what you are going to do.
did you have to modify the 47-53 bracket at all to make it work?? I am doing a small block with a 400 trany. Thanks for the advice.
it was in the truck when i got it,but it looks like nothing was modified on the bracket at all. The only thing the previous owner told me that he did was to move the motor back just a little bit to clear the steering box with the exhaust. Hope that helps.
Mike
