1 members (Rusty Rod),
99
Mod | | | Forums66 Topics128,193 Posts1,057,260 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 3 New Guy | | New Guy Joined: Dec 2008 Posts: 3 | I am building a 46 1/2 ton but need help with what bracket to use with a powerbrake booster and leave it under the floor. You can buy them for 47 and newer but not for 46's. any one have suggestions. Please help. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I wonder if you could buy the later one and fabricate it to fit your truck.
~Jim
| | | | | Joined: Apr 2005 Posts: 35 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 35 | the one on my 46 is the one for the 47-53 and fits fine. I have a small block and th350 trans and not the original 6. Not sure what you are going to do. | | | | | Joined: Dec 2008 Posts: 3 New Guy | | New Guy Joined: Dec 2008 Posts: 3 | did you have to modify the 47-53 bracket at all to make it work?? I am doing a small block with a 400 trany. Thanks for the advice. | | | | | Joined: Apr 2005 Posts: 35 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 35 | it was in the truck when i got it,but it looks like nothing was modified on the bracket at all. The only thing the previous owner told me that he did was to move the motor back just a little bit to clear the steering box with the exhaust. Hope that helps.
Mike | | |
