2 members (Tronman, Gray_Ghost), 85 guests, and 1 robot.
Topics128,142
Posts1,056,476
Members48,441
I have been trying to find out what engine my 1955 2nd series has in it. i think that it is a 235 but there is no casting number on it. i dont know if it was ground off or if the factory forgot toinclude the number in the casting. so could anybody help me with this
1955 First Series Chevy 3800 Dually
Photos on Flickr
What is the stamped number on the boss just behind the distributor?
the number you want is 'Cast' not stamped, can be found below or near the fuel pump. Also get the 'cast' number off the head will help. Could be a 261, look just above the starter for the 'II' captains bars, but some early 235s had this marking.
1946 1/2-Ton Chevy
Ideally, both numbers would be best to get an accurate ID. The casting number JiMerit mentions will get you in the ballpark, but the stamped number behind the distributor that waldo53 mentions will give the original application. However, if the engine was a service replacement that was installed after the truck was originally sold, then it may not have that number, as the usually were not stamped.
Once you get the casting numbers, check here to decode them. If you have the serial number from behind the distributor, post it here. I have the truck numbers (and some pasenger car) up to '72.
Bill Burmeister
There is no number by the distributor, the head is a 235 head
Photos on Flickr
Here are locations of casting codes and the engine number on late 235/261 engines. These locations might be the same on your engine,
Post the casting codes AND date codes for your head and block. People here will be in a better position to help you.
When did Chevrolet move the casing numbers from near the fuel pump to the location shown in tclederman's link? Was it with the other changes from the the 1954-55.1 engine? Here are the casing number locaions on a 1954 261.
I also have a later 261 that has the numbers shown in tclederman's link. If the block is a replacement block from Chevrolet, neither the serial number (as mentioned above) or the casting number is 100% proof of identification. I have a 1954 261 block (shown in the link above) that has a 235 casting number and no "Captain's bars." The block was purchased new from Chevrolet by the previous owner.
hoyt,
I'd like to hear someone else's answer to your questions. Oddly, I have not checked my 1954 engines, but will do so tonight. My guess was that the change was made in late 1955.
Does anyone have information on locations for pre-54 235/216 engines?
Tim
Getting back to jmiller's question - I was at a cruise-in last Fri. and a guy came in with a '50 Chev 3100 with an engine that sounds a lot like what jmiller describes. I could find no casting numbers on the block and there was no stamped numbers on a raised boss behind the distributor. I finally caught up with the owner and asked him what the heck it was - 302 GMC.
Getting back to jmiller's question?
jmiller55,
Just post the codes you find and people will try to help you.
uhhh, yeah, I was suggesting he might have a GMC engine.
Perhaps a picture of the engine in question might help.
Bill Burmeister
I pulled the distributor and there was a number in front of it between the fuel pump 3764476 it is a 58- 62 235 thanks for all of your guys help
Photos on Flickr
U
U Offline
I found the following numbers on my 235 engine for my 1957 Chevy truck. To the left of the distributor the number is: F424H.
To the right of the distributor the number is 3837004 GM 13.
On the carb side of the head the number reads: 3836848 GM 28.
On the frame right along the front driverside tire the numbers are: 1570114510. Can some one give me an idea if this is the original engine for this truck? Thank you for help. Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
Jon,
That is a 56-62 235 head. Someone else will have to help with the block casting code.
Is there a block date casting code (most likely on the lower left of the distributor side of the block)?
Tim
According to one of the casting # links on the Inliners site, 3837004 looks like a 55-57 235.
Hoyt
U
U Offline
Tim I will take a closer look. Thank you.
Jon
More pix
U
U Offline
Hi Tim and gang,
OK I had to pull the starter off to find the ID. The number is:
"CON4 D197" Does this mean it was January 1957? How do I check to see if this is the original engine for this truck?
Thanks for the help!
Jon
More pix
My guess:
D197
D = April (Dth or 4th month)
19 = day of the month
7 = 1957
You'll never know if it was the original engine unless (1) you have the original title/registration, AND (2) the original title/registration has the original engine number as the VID/VIN (it could be an engine code or a door-post-plate code).
Now, do you want to check to see if the head date-casting code is also for 1957?
U
U Offline
Tclederman & Hoyt,
Thank you for the information. Next time I am up at my moms I will take a look at the original registration paperwork.
tclederman,
The head casting number reads: 3836848 GM 28
More pix
We identified the head (above) as a 56-62 head. If you want to determine the year of the head, the location of the head date-casting code is shown in photo 7 in the link in my post above.
U
U Offline
tclederman,
Thank you for your time and link to the photo.
Jon
More pix
