2 members (Wooley, 59 fleet),
70
Mod | | | Forums66 Topics128,096 Posts1,056,488 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | So here goes, I just got the linkage and new fuel lines all squared away from replacing 2 rochesters for 2 of the carter webers that tom langdon sells. Now that it is all hooked up it wont run. I can get it to catch for a bit, (maybe 5 sec) and then it is at a pretty high rpm and it just dies. I am lost, I have good spark, fuel, what am I missing. It ran before the swap but I was having a few issues with the rochesters.
The set up is on a 235 with fenton intake and exhaust.
Brian
1946 1/2 ton I'm not addicted I just don't know when to stop
| | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | I'm going to take a shot in the dark and guess that your air/fuel ratio is off, being too lean. What are you doing to get it to start? Just cranking? Cranking while pumping the throttle?
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Brian,
What type of choke set up do you have?
Tim
| | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | I currently have it set up with an electric choke, while starting I am giving a couple of pumps to set the choke then cranking.
I feel like it shouldn't take much to start but it still has me puzzled.
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
| | | | | Joined: Aug 2005 Posts: 107 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 107 | Turns out I had a major vacuum leak and now it runs really good. Thanks for ideas and help, this site has been super over rebuild.
Looks like I get to go for a ride today after all
Brian
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | It is that giant sucking sound that Ross Perot mentioned | | |
