1 members (Materman), 107 guests, and 3 robots.
Topics128,072
Posts1,055,906
Members48,429
1950 One Ton. I better edit my signature right after I post this.
So, you know how you're supposed to adjust your driver's door, so if you close it it won't lock.... And how you aren't supposed to lock the passenger door from the inside, because the key won't unlock it from the out side....
I was driving home, shoved my tool bag against the passenger door, which locked it I guess, got out of my truck on the drivers side, instead of sliding across the seat, cause the tool bag was in the way. Locked the drivers door, and as I slammed it, noticed how the passenger handle was pushed forward. Dang.
So, what's the slim jim I need look like?
My friend has AMA, so I'll likely get her to get the truck opened. But I'm guessing this won't be the only time I do this. If I'm not around when the truck gets unlocked, does anyone have a pic of what the device looks like?
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
pull the lock out of the window H-channel, and remove the rear window if it is a 3-window, or the corner glass if it is a 5-window. Should take only a few minutes. I have used a plunger to pull on the glass and to keep from dropping it, however a glass suction cup would work best.
How did you manage to get the door to latch with the lock engaged? It won't do that on a '52 and later door.
I don't know if it's supposed to. If you slam the door hard and fast enough, like when its pouring rain.... Like here.
I'm going to have to check that out, this weekend. I'm still waiting for the tow truck guy. I do remember it saying something about this, seems to me that it said "kid, if your door latches aren't adjusted right, this could happen to you"
Ahh, the lock on my weather strip is on the inside, and its pouring rain, and cold and dark.
Fortunately I am sitting inside on my couch.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Gosh Mr. lang, it's only 82 degrees here. Next time you lock yourself out do it here. I did the same thing in a 51 back in 69. I called a locksmith...
~Jim
The tow truck guy's gone now. Well , actually the second one. The first guy couldn't do it. Dang, I've got to get one of those long coated wire things. I'll bet I could find dozens of uses for it...
I see now what to do. Best not to let this happen though.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Last resort Christopher.....Cut the rear cab glass rubber.
It might be cheaper than calling a locksmith!
P.S. Why did you install the rear with the lock strip inside?
Was it for looks?
More pix on Flickr.
i know this won't help you now but in the future. take the lock off the passenger side and move it to the drivers. i did mine years ago. it is an easy swap. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I thought the lock strip was supposed to be on the inside.
The "lock out" was free, because of my friends AMA card. I should get her some flowers or something.
For now, I'll just be more careful.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Easy
You could have crawled under the truck. Unhooked and taken the battery out. Opened the cover over the battery in the floor. Rolled back the floor mat. Then taken a coat hanger to open the door.
Next time you know what to do.
Hehehe
Go McGyver
Dennis
You guys from Texas have all the answers huh?
I can't believe I never thought about that.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1926 Model TT Truck
Opinions is a better word for this.
I am glad all worked out.
Dennis
Texans continue to amaze me. I think that is the right word.
Don't you wish we were closer to Canada?
You could enjoy armadillos. Land oysters in a half-shell.
Dennis
You eat those things? No way.
Lotsa hot sauce?
oops better shut this one down..back to the spoon. wave
There's nothing wrong with it being inside,it's just generally fitted to the outside.
If you were to use a 'chrome'decorative lock strip it would be a bit pointless having it inside the cab! grin
Re;The "lock out" it goes to show it's not what you know...but who you know.thumbs_up
More pix on Flickr.
And I always thought the only use for power door locks were to save labor. You may have convinced me to go that route. grin
~Jim
I just filed the battery door removal under very useful information in my brain. Now if I can just pull it back up if needed.
Originally Posted by oldbluetruck
Easy
Hehehe
Go McGyver
Dang Dennis, how many trucks have you stolen? grin
~Jim
Please guys, this forum is for business. Take the off topic banter to the Greasy Spoon. Thanks.
I've watched a expert with one of those vinyl covered special bent rods before. The last time I needed to call for one, the first one gave up and left, and it was the second one who managed to get the door open.
This was on a modern mini-van with power door locks and she ended up simply pushing the unlock button with her bent rod.
Now if you think buying one of those vinyl covered special bent rods is the right answer please tell me where you are going to carry it. When I had my little experience both the keys and the remote opener were inside the van. Where I left them.
Probably the same place the vinyl covered special bent rod would have been if I owned one.
I enjoyed the battery cover suggestion. If your truck is like mine you would not mess with the battery cover though, you would just poke something up through one of the rust holes in the floor.
