| | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 23 New Guy | | New Guy Joined: Apr 2009 Posts: 23 | Hello, this is my first post so if something is not correct that is why. I am restoring a 1947 Chevy COE truck. I took the seat frame out to rebuild it. There is a cable that goes around two pulleys on each end. It is a continues loop and doesn't seem to have function. I have other trucks a little newer that doesn't have this cable. Does anybody know what the cable inside the seat frame is for? It doesn't seem to have a function other than for strength. Thanks, Steven T.
Believe none of what you hear and only part of what you see
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It's my understanding that the cable helps to make the seat slide squarely front to back, both sides travels at the same rate, not crooked. My 48 seat frame has the same arrangement, but I haven't worked on it yet.
Grigg | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I was thinking that but the pulleys sort of threw me off. My littlebolt has a cable but as I recall it only goes from one side to the other w/o a loop or pulleys. It attacjes to the seat position track locks as Grigg described. However I thought COE all had separate driver and passenger seats (?) that would not require such a device. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | The Chevrolet COE's have a full seat cushion, & full seat back. The GMC COE's have a split cushion, & full seat back. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Another day and another thing learned. Thanks. | | | | | Joined: Apr 2009 Posts: 23 New Guy | | New Guy Joined: Apr 2009 Posts: 23 | Hey thanks for responding to my question. After doing more research there may be something missing that attatches the cable to the slide mechanism on each end of the seat frame. I found a small section in a service manual that talks about adjusting the cable tension, but thats it. It does show a picture of the tensioner and cable, but I'm not sure how to show pictures on this site. I took a picture of my seat frame also, I would like to show. Thanks, Steven T
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | It sounds like the clamps are missing that attach to the cable on each side. I'm going by memory, but the clamps are about one inch long and maybe a 1/2 inch wide and are held with one screw. Hope this helps. Cleon | | | | | Joined: Apr 2009 Posts: 23 New Guy | | New Guy Joined: Apr 2009 Posts: 23 | Thanks 31,32,33 for responding, I need to find a picture of a seat frame cable clamp so I can make a couple. Any body out there have a seat frame that still has the clamps intact, or a picture out of a body repair manual so I can see what they look like?
| | | | | Joined: Apr 2009 Posts: 23 New Guy | | New Guy Joined: Apr 2009 Posts: 23 | Thanks 31,32,33 Bigtime help, Im trying to restore this truck to as original as possible and this will help. When I get it figured out how to post pictures I'll get some on here of some of my stovebolts. Thanks again Cleon! Steven T
