6 members (Gdads51, Joe H, Gray_Ghost, Hambone, TUTS 59, Otto Skorzeny), 121 guests, and 1 robot.
Topics128,085
Posts1,056,091
Members48,434
#535078 05/05/2009 11:02 PM
Had my 57 truck running for a little while and don't feel that comfortable with the force required to stop fast.
I have a MasterPower dual diaphram w/ corvette style mstr cyl.with 4 wheel disks and all the proportioning stuff they recommend.
Masterpower recommends 18-20 inches of Vacuum at idle, I have 15 which is at worst case about 25% shy.
My question is has anyone used an electrical vacuum booster and does that extra 5 inches make that much difference?
Rich
In many cases high performance engines will not have enough vacuum for the brake booster to operate correctly. The system you installed should be more than adequate and require only moderate pedal pressure to stop at high speeds. You have a vacuum problem and a vacuum booster and possibly a storage canister may help. Check out www.abspowerbrake.com. They offer an electric booster that uses no vacuum. It is essentially the system used in late Corvette's. It's pricy but would eliminate any vacuum issues.
Fred
Early GM (50's) power brakes used a vacuum reservoir that was nothing more than a 46 oz. Donald Duck style OJ can with a little nipple soldered on for attaching the hose. Worked fine. Just solder up the openings, add the connection and away you go.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
