2 members (Hotrod Lincoln, Hush), 58 guests, and 4 robots.
Topics128,021
Posts1,055,355
Members48,420
Hi guys,
The trucks what use double rear leaf spring package, what is the purpose, to carry on more load although the capacity is 3/4ton(for example)?
thanks
They are called helper springs. They engage brackets on the frame after some weight has been added, then they continue to help carry more weight.
1952 Chevrolet 3800 pickup
---All pictures---
Those springs help to stabilize a loaded truck as much as anything else.
If the truck is never loaded they may never be used, but as you load the truck, those so called 'over-load springs' add roll stiffness thus improving handling. Without them the truck could be scary going around corners.
1 Offline
Everything said so far is true but another added feature is it allows you to carry more weight with out having the stiffness (and rough ride) that it would actually take if the springs were up graded in a single set deal.
Basically they allow you to keep your nice ride (or semi-nice ride if you have a 2-ton truck like me) while empty but still be-able to haul a lot of weight without squatting the truck.
1947farmer
1947 2-Ton Chevy
Story in the Stovebolt Gallery
More pix in Photobucket
1977 3/4-ton
1985 2.5-ton
2- 1947 Allis WC
1- 1949 Allis allcrop
1- 1955 Allis WD-45
1- 1976 Allis 7040
"If it ain't broke you ain't trying"
Ok guys, thanks. ¿but this package was not RPO?. Why not all the trucks use it?
They were optional on some models such as my 38. mine is the long wheel base without helper springs but I have seen short and long wheel base with them. less equipment standard meant lower cost buyer could add what they wanted. My grandfather said he intially tried to get by with adding leaves to the helper springs to increase the capacity on his 47.2 chevrolet tractor but when he loaded it the helper springs caught the brackets and broke them off. better to build up main spring. Can't imagine how rough that would ride empty.
the auxillary spring pack was optional based on the GVW rating of the specific truck .... note in your manual that any nominal rating has a range of GVW's, the lower GVW is the "base" truck, higher ratings had different tires and/or wheel sizes and for some of the nominal ratings, the highest GVW has "aux rear springs" under 'equipment' ... commonly called 'helper springs' or 'overloads' in the day
