| | | Forums66 Topics128,014 Posts1,055,333 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 55 New Guy | | New Guy Joined: Jan 2009 Posts: 55 | I'm ready to paint over some areas in my cab that will be covered with the patch panels. In order to stop future rusting I plan on using Eastwood's Rust converter and rust encapsulator. The problem is these products contain toluene, xylene, naptha, and Pet. dist. products all very harmful products. I cannot get information as to which respirator would be safe to protect me from these harmful chemicals. Some respirators seem like they would work, but I want to know for sure they are working. If you can give me some definitive guidelines please respond. Thank you----- | | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | Call 3M safety 800-243-4630 for correct info
They can tell you correct mask/respirator you may need
| | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | You need a forced air respirator. Only one set of lungs.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
| | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Funton, I used both products on mine ...THE BRUSH ON VERSION, with the brush on version I used a charcoal respirator and had the ceiling fans on in the shop an the door open, smell and fumes are very, very minimal with both products. Now if I was sprayin the product I would be more concerned bought atomized particles in the air and would definately be lookin for a better respirator. The Eastwood rust converter BRUSH ON ..goes on like water & the encapsulator is like thick arse Honey. Tim | | |
