1 members (Shade Baby),
21
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 24 New Guy | | New Guy Joined: Aug 2007 Posts: 24 | Question I need to replace the front bumper and brackets, I have a 2 ton is the bumper the same for all 1940 Chevy's or do I have to look for a special type | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy alberta chevy, I've seen a couple of different styles on the larger trucks, but they're definatly different than the 1/2 - 1 ton ones, hope that helps. | | | | | Joined: Mar 2009 Posts: 169 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 169 | Gerard have you tried Scotts in Penfold have gotten parts there before...There are sure some cool wreckers in the north of alta | | | | | Joined: Mar 2009 Posts: 169 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 169 | Gerard have you tried Scotts in Penfold have gotten parts there before...There are sure some cool wreckers in the north of alta | | | | | Joined: Aug 2006 Posts: 36 Apprentice | | Apprentice Joined: Aug 2006 Posts: 36 | I have a 40 1 1/2 ton here in Manitoba. The bumper on it was the same as on a pickup, and chromed as well. I am very certian that this was the origional bumper.My 41-46 2ton has a considerably wider and heavier bumper,non chromed.Are you sure your truck is a "2 ton".I was under the assumtion that they wer'nt started till the 41-46 series, with a heavy plate riited to the outside frame rail for extra strength!I am thinking your 40 will be the same model as this one I have, a 1 1/2 ton.If you would like to post the model number, I will get the one of this and compare. Jim | | |
