1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | Just bought it. The engine is a 50-52 235. Is this a splash fed or full pressure motor? It is a manual. Would a powerglide bolt in without modification? Anyone have a full pressure 235 that runs good? This one is knocking.... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Splash oiler. If it is a 235, the it is already a 'Glide engine (manuals had 216s), but it would not be the full pressure. Those came out in '53. The engine should bolt right up with no real issues.
Bill Burmeister | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | The OOOOOLD cast iron powerglide will bolt up if you have the adaptor ring. I wouldn't rebuild that motor, you'll find a 54 or later one around, mucho better. | | |
