| | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | I have to assume the power supply on my '63 Grumman 292 is a generator, correct?
Question 1} how to tell the difference between a generator and an alternator?
2} What are the steps for switching to an alternator?
On yesterday's test run, I found that I am not making enough juice to run the large inverter I installed. This inverter is intended to run a small electric refrigerator and 5000btu AC unit during travel. The 120vac power needs when stationary will be from direct hook-up to an AC outlet or from a portable AC generator. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | For the most part a generator is long and black while an alternator is about half as long, bigger around and silver. I don't have any experience with an inverter so I can't comment.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you won't find an alternator that'll support that inverter load and still leave enough power from a 292 to move the truck, you should be looking for an RV 3 way fridge and using vehicle AC
Bill | | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | Have you priced a 2 or 3 way frig?
After further inspection, it looks like it has an alternator, obviously underpowered. I am thinking an HO alternator, battery isolator and 2nd battery may do the trick.
The temptation to simply run the portable generator is strong. all I have to do is move an AC inlet to the rear bumper deck. Certainly cheaper! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes I have, and investigated all the alternatives, which is why I'm going with a top line DC only marine fridge  no point in wasting money buying constant frustration ....but in your case, a propane/110 fridge could easily be found used very reasonable here's a bit about bigger alternators [biggest you could use], but a 2nd battery will just add to the load, even if you use deep cycles .... I'd suggest spending some time studying mobile electrical systems - with that van you have the perfect platform for solar panels Bill | | | | | Joined: Feb 2009 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 137 | Red, I love Da Bus! Sa-weet!
| | | | | Joined: May 2009 Posts: 117 Shop Shark | | Shop Shark Joined: May 2009 Posts: 117 | my rv has a regular alternator and 2 batteries with a isolator the engine battery only runs the engine part and the coach battery runs my fridge, tv, microwave, pc, etc ,etc with no problems if the battery for the coach gets drained the isolator keeps power from being drained from the engine battery. in turn only the battery that needs charging at the time gets charged by the alternator breaking up the load so to speak also, my ac to dc converter also has a charger built into it so it charges the coach battery when were plugged into shore power. how ever our fridge only runs for a breif time to cool the food store and then stays closed and cold untill hooked to shore power. for long drives the fridge thermostat kicks it back on when it needs to cool. hope that helps
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | http://images.google.com/imgres?imgurl=http://www.rowand.net/Shop/Tech/images/GmGeneratorAndAlternatorComparison.jpg&imgrefurl=http://www.rowand.net/Shop/Tech/GmAlternatorIdentification.htm&usg=__r4a3v8YhearfR56J9uXRKo6qecM=&h=560&w=384&sz=30&hl=en&start=1&tbnid=jTiezT1l_NfTRM:&tbnh=133&tbnw=91&prev=/images%3Fq%3DGM%2Bgenerator%26gbv%3D2%26hl%3Den%26safe%3Dactive
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
