| | | Forums66 Topics128,004 Posts1,055,265 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | i did a search and tried to id my block but i cant make sence of the #s i have.
the sunk #s behind the distributer are F425H.
the only thing i can decifer is that it was made in freemont, ca.
thanks.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | My guess (wait for some one else, before accepting my guess):
F 4 25 H F = Flint, MI 4 = April 25 = 25th day of April H = manual transmission - 1957 truck engine (235)
I'll bet that over 80% (>90%?) of the people who have been assured (even by family members) that it is the original engine find out that the engine is from a different year. Owners and shops thought nothing about swapping engines to keep these trucks working.
Does it have 4 slits in the valve cover? (54/55 did, but the VCs were easily replaced)
Does the water pump body go above the bottom of the front of the head (54/55 did)? (post a photo - or email me a photo, if you want)
| | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | it does have slits in the valve covers and the water pump does not go above the bottom of the head. i'll get a pic up tomorow. i'm headed out to a bbq.
thank you for your help.
| | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | i'm waiting for my wife so here they are. water pump | | | | | Joined: Apr 2009 Posts: 187 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 187 | I just recently purchased a 50 Chev pickup and the engine block numbers I found on the distributor side underneath the fuel pump. The numbers you mention refer to the place, year the block was made. I did find a serial number as well on the machined surface beside the distributor but no one can tell me what it might indicate
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If you want to know what your Canadian engine casting number indicates, look here:
http://cc.msnscache.com/cache.aspx?q=chev+casting+3695451&d=75971765944818&mkt=en-CA&setlang=en-CA&w=35b368bb,fb9e138b
Just scroll down until you get to yours.
