6 members (Donf, Nick in Manitou, 1955 1 Series, jay d, 2 invisible), 87 guests, and 1 robot.
Topics128,115
Posts1,056,633
Members48,450
i finally found the tranny that ive been searching for the past 3 years at a local junkyard. (YES!!!) the thing is that it looks like its been dropped tailshaft first into 3 feet of mud. everything is covered in crusty oil soaked mud. how would u guys go about cleaning it so its ready for paint?
p.s. all the gears turn wonderfully, so i really dont want to have to break into it if i dont have to.
Let it dry
ANY oven cleaner
spray w/ (high pressure) hose
works on frames, front & rear ends, engines. etc.etc.etc.
Jim & Caroline
is there a possibility of mud and water being pushed thruough inside the transmission by pressure washing it? i immagine neither would be good on the gears
You will likely want to change out the fluid in it regardless. Get out all of the old crap from sitting in the junkyard & if some water gets in while cleaning you'll get that out too. Should be no problem.
cool thanks for the input guys, ill get to work
Apprentice
Apprentice
Haven't tried oven cleaner before, neat idea.
The higher the temperature of the transmission and the water, the easier the gunk will come off.
I have used a gasket scraper and wire wheel on grinder to good effect. Takes a while and ends up being like an archelogical dig! Then a bit of carb or disc cleaner (disc is less nasty than carb) to get the final spoo off.
I just wait until late and truck it down to the car wash,dose it with oven cleaner and pressure wash it clean.they don't even call the cops anymore.
As long as you have a driveline yoke in the tailshaft housing and go kind of easy around anyplace a shaft goes into or out of the gearbox,it'll be okay.You can even wax it so it won't grow any more rust for a while.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
