2 members (porsche, Uncles51),
55
Mod | | | Forums66 Topics128,021 Posts1,055,356 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 108 | So I follow the directions regarding bench bleeding - my M/C came with little plastic fittings & hose supplied - nice touch! Step 1 is no problem - remove the output fittings that go to the PPV and replace with the plastic fittings & hoses which are routed into the fluid. Mission accomplished - got all air out & the unit is bled with the hoses into the reservoir. So what then - you just disconnect the plastic couplings and refit the lines to the PPV?  I assume purpose is to ensure there is no air in the cylinder - disconnecting the output will drain fluid after that, but as long as the opening port remains submerged, there should be no impact to the cylinder - is that correct? When I go to bleed complete system, I have a vacuum bleeder incidentally. Makes life really simple - was a good investment. I have the MightyVac brand that operates off a venturi from compressor
'51 Chevy 3100 Truck - OEM 216 Engine; three speed column shift transmission 6 Bolt disc conversion with dual master/vacuum booster 12V alternator conversion. 235 engine in waiting | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I assume purpose is to ensure there is no air in the cylinder - disconnecting the output will drain fluid after that, but as long as the opening port remains submerged, there should be no impact to the cylinder - is that correct? I left the plugs in place 'till I had all my hard lines bent and ready to install,only at the last minute did I remove the plugs and quickly fit the brake pipes. Fluid loss was minimal and I simply bled the system as normal. I did it the old fashioned way, i.e. no fancy vacuum bleeder!  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The purpose of bench bleeding is to bleed the MC while it is in a level position. That way there won't be any air trapped that won't get pumped out. That's a good idea for the MCs that are mounted on the firewall as most seem to be sitting at an angle and not level. However if your MC is located on the frame it should be level and therefore bench bleeding not needed.
~Jim
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | "...and therefore bench bleeding not needed."
Wrong | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 |
~Jim
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | You can mount the master cylinder in the truck and attach the brake pedal linkage and follow the "bench bleeding" procedure as described by D'Ecosse in the above post. Pressing the brake pedal slowly and watching for all the air bubbles to disappear. Then remove the plastic plugs, attach the steel brake lines and then bleed the entire system. This method has worked great for me many times, especially when the master cylinder is mounted under the floor. If the master cylinder is mounted on the firewall you will need an assistant to slowly press the brake pedal while you are tending to the master cylinder on the firewall. An old time mechanic taught me to do it this way. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i bled my [new] whole system while mounted on the truck W/O any problems or issues. No bench was bled upon... it worked great w/ a coke bottle and tube
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2007 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 108 | I did the bench bleed anyway, not a big deal
Installed the master & new hard lines yesterday.
I ran a new 1/4" from the 'rear' output of the PPV to the OEM TEE on the right frame rail that was originally common for both front & rear; plugged the output of the TEE that previously fed the front. (I 'stole' the plug off the extra port of the PPV to use in the TEE.) I actually left the rear lines as-is from there, they were in great shape.
I decided to run individual lines to the front since the PPV had that capability with two output ports - it appeared much simpler than running per the OEM set-up with a TEE at the front right corner and a line across the front back to the left side. Less fittings this way! So I ran one-piece direct line straight down the left frame rail to the front left caliper; and the other followed the 1/4" line over the forward transmission crossmember, then down the right frame rail to the right front caliper. I had to put a union in that run since I was using pre-made lines - longest I could get was 5'.
Bleeding was a snap with the vacuum bleeder. After I did all 4 corners, I actually got the Mrs out to work the pedal so I could do a couple of strokes of manual bleeding at each node as a final step, just to be sure I was good.
Just the vacuum line to hook up now - I actually created a new post with some questions on fittings for that.
Incidentally I have an unknown part left over from the kit - this was actually in the same bag as the bleeder kit (i.e. the fill bottle, bench bleeding fittings & hoses) - this is a metal ring, about 2" OD x 1-1/2" ID x 2" tall (guesstimates - did not actually measure) - any clue as to what that is for?
'51 Chevy 3100 Truck - OEM 216 Engine; three speed column shift transmission 6 Bolt disc conversion with dual master/vacuum booster 12V alternator conversion. 235 engine in waiting | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | D'Ecosse It looks like your making good progress. The metal ring sounds like a spacer for the pedal pivot. If you were converting from a clutch to auto the spacer would replace the clutch pedal lever. I didn't get one with my kit so I simply cut off the arm and retained the pivot section. It does exactly the same job. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2007 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 108 | ...The metal ring sounds like a spacer for the pedal pivot ... Ahhh, that makes good sense Jock - I'll toss it in the tool-box for a rainy day - you never know what's down the road! Now that it will stop better, moght get the urge to make it go a bit swifter!
'51 Chevy 3100 Truck - OEM 216 Engine; three speed column shift transmission 6 Bolt disc conversion with dual master/vacuum booster 12V alternator conversion. 235 engine in waiting | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If your anyway like me you better label that spacer cause when the time comes you won't remember where or what it is.
~Jim
| | | | | Joined: Aug 2007 Posts: 108 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 108 | ... when the time comes you won't remember where or what it is.  I won't remebember where what is?  (they say it's the second thing to go!)
