5 members (Ponchogl, MickeyP, Bill Marlow, 48jim1ton, 1 invisible), 119 guests, and 0 robots.
Topics128,049
Posts1,055,552
Members48,425
#531798 04/24/2009 8:25 PM
Can a 52 216 from a sedan go into a 1953 3100 truck?
Do they both have the same front mount?
TIA
Dennis
oldbluetruck #531805 04/24/2009 8:50 PM
I think the 51-52 car motor will have side mounts at the front. You may have to swap the front cover plate off of your truck motor.
Professional Novice
Frank50 #531847 04/25/2009 12:14 AM
Thank you. I found a good running 1952 216 from a Chevy sedan and wanted to put it in my truck.
I will see how it works out.
Dennis
oldbluetruck #532191 04/26/2009 2:26 AM
Apprentice
Apprentice
Are the spark plugs from your motor 13/16 hex or 5/8?
pgossett #532197 04/26/2009 2:36 AM
It is a nice engine. I picked it up today.
I think that I will have to use my old bell housing but the water pump is that of a 216. It does not have the front mounting so I will have to drill it out.
I think the cars had the key start. I wonder if I can make that work in the truck?
It is 6 volt. That is cool.
Dennis
oldbluetruck #532288 04/26/2009 12:17 PM
If you have a key start setup on the motor than it should work just like it did in the car. I am not commenting on the two flywheels here as I will leave that to others. You will need to provide a momentary switch like a push button for engaging the starter solenoid.
1951 1 Ton Completed
truckernix #532651 04/27/2009 2:47 PM
Cleaned her up a bit on Saturday. She turns over. That is a big plus. I have never bought one that turned over before. But only one was trashed. So. I am encouraged.
The harmonic balancer is different. On the front is a 'reach out an grab ya' fitting. I guess that is for the manual crank.
I wrote down the number. It starts with KAA which shows to be a 216 for automobiles in 1952 - that is nice. Then the 4 diget assembly number (5966 - I think). But then there is a 9I stamped. Don't know what that is?
Back to the starter. Can I get a 1952 car key switch and use it on my truck? I am sure I will have to change the bell housing. And if I leave the current starter/flywheel on the engine I should be able to use the current set up. I don't know the differences in the two switches and wiring. I think the wiring could be worked out.
What do you think?
TIA
Dennis
oldbluetruck #532686 04/27/2009 5:53 PM
If you choose to go with the key-start system any universal type ignition switch with a spring-loaded start position can be made to work with the solenoid-engaged starter. The original equipnment ignition switch for a passenger car would work, if you're interested in keeping things all-GM, but that's not really necessary. Another option would be to keep the truck ignition switch and just install a pushbutton switch to engage the starter, like the Hydramatic-equipped trucks did. Those switches mounted on the left side of the dash, just above the parking brake release knob.
