8 members (1955 1 Series, NJC, WICruiser, 51sub, greenie-reddy, Peggy M, Tronman, Gray_Ghost),
120
Mod | | | Forums66 Topics128,265 Posts1,058,360 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Can a 52 216 from a sedan go into a 1953 3100 truck? Do they both have the same front mount?
TIA
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Nov 2000 Posts: 1,975 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,975 | I think the 51-52 car motor will have side mounts at the front. You may have to swap the front cover plate off of your truck motor.
Professional Novice
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Thank you. I found a good running 1952 216 from a Chevy sedan and wanted to put it in my truck.
I will see how it works out.
| | | | | Joined: Feb 2007 Posts: 33 Apprentice | | Apprentice Joined: Feb 2007 Posts: 33 | Are the spark plugs from your motor 13/16 hex or 5/8? | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | It is a nice engine. I picked it up today.
I think that I will have to use my old bell housing but the water pump is that of a 216. It does not have the front mounting so I will have to drill it out.
I think the cars had the key start. I wonder if I can make that work in the truck?
It is 6 volt. That is cool.
| | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | If you have a key start setup on the motor than it should work just like it did in the car. I am not commenting on the two flywheels here as I will leave that to others. You will need to provide a momentary switch like a push button for engaging the starter solenoid. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | Cleaned her up a bit on Saturday. She turns over. That is a big plus. I have never bought one that turned over before. But only one was trashed. So. I am encouraged.
The harmonic balancer is different. On the front is a 'reach out an grab ya' fitting. I guess that is for the manual crank.
I wrote down the number. It starts with KAA which shows to be a 216 for automobiles in 1952 - that is nice. Then the 4 diget assembly number (5966 - I think). But then there is a 9I stamped. Don't know what that is?
Back to the starter. Can I get a 1952 car key switch and use it on my truck? I am sure I will have to change the bell housing. And if I leave the current starter/flywheel on the engine I should be able to use the current set up. I don't know the differences in the two switches and wiring. I think the wiring could be worked out.
What do you think?
TIA
| | | | | Joined: Feb 2004 Posts: 29,945 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,945 | If you choose to go with the key-start system any universal type ignition switch with a spring-loaded start position can be made to work with the solenoid-engaged starter. The original equipnment ignition switch for a passenger car would work, if you're interested in keeping things all-GM, but that's not really necessary. Another option would be to keep the truck ignition switch and just install a pushbutton switch to engage the starter, like the Hydramatic-equipped trucks did. Those switches mounted on the left side of the dash, just above the parking brake release knob. Jerry
