5 members (JW51, Otto Skorzeny, Donf, Bill Hanlon, 1 invisible), 68 guests, and 2 robots.
Topics128,084
Posts1,056,334
Members48,442
#532184 04/26/2009 2:13 AM
after having my gas tank acid dipped and painted in my 46, i installed it today only to find a small pin hole, does anybody have a repair short of replacement or welding?
jrm4x4 #532193 04/26/2009 2:30 AM
Y
Y Offline
Gas tank sealer. I've used the POR 15 brand for (3) tanks and no problems. Do a search and you'll find the topic well covered, on what to use and how to do it.
any rad shop can solder repair the gas tank....
GMC: Get More Cash...
1958 GMC
My Webshots photos
JB Weld will do the trick. If you want too braze or soder it remove the tank.use another car start it up use a hose from the running cars exhuast to the tank to be repaired.let run for 10min or so.with the hose still in the tank an running,now you are safe to use a torch.No oxygen No boom.Water is a no no,
dan-pa
1958GMCnut #532284 04/26/2009 11:10 AM
Ex Hall Monitor
Ex Hall Monitor
I couldn't find a radiator shop within 50 miles that would touch a gas tank. Depends on where you live I suppose. ohwell
Tiny #532318 04/26/2009 2:50 PM
I would agree with Tiny on that. Besides you wouldn't like what the tank would go through to weld that hole. First you would want to remove it and then they would fill it with water to weld it. A bunch of trouble and aggravation you won't like. Use the JB Weld - problem solved.
~Jim
jrm4x4 #532448 04/26/2009 11:07 PM
removed the tank, used the jb weld refilled the tank and no leaks, thanks guys.
jrm4x4 #534163 05/02/2009 4:27 AM
I used solid type (Not liquid) epoxy that you knead to activate.
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
I had to pull my tank (sat for many years) because it was full of varnish. Simms Radiator here in Atlanta hot tanked it for me, pressure tested it and painted it for $65. Told me that if it leaked, they'd line it for another $75. No leaks found - honest folks here didn't try to sell me something I didn't need.
David Bush
