1 members (klhansen),
126
Mod | | | Forums66 Topics128,131 Posts1,056,726 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 27 | Hi all. I have not been too active here, but stovebolts have never left my heart. The economy has hit hard and the "bolt" has been put on the back burner.My torque tube diff is gone daddy gone. Someone drove it empty until it stopped. It was that way when I bought it. I recently found a craigslist post with a 53 Sedan diff available for 75 bucks. Almost too good to be true. I'm wondering if it would fit my truck. Mine is a manual trans and I don't know what trans is on the Sedan. Any help guys?
1954 Chevy 3100 235 2 Yamaha YSR50's 05 Silverado crew 00 Yamaha TT-R125 Supermoto
| | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | convert it to open drive now is a good time | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Yes it can fit and I have the how to listed in Tech tips. I ran a passenger rear torque tube for years under my 46 half ton. Also the gear ratio shoule could be 3:55 if the car had automatic and the stick shifts were around 3:70 in 53.
Having said that, I like open drive much better, allows to swap to a modern type trans, lots of ratios etc.
| | | | | Joined: May 2003 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 27 | I've thought about the open drive conversion many times. I plan on eventually doing a no holds barred restoration one day but now .... I just would love to drive past my driveway. I have not seen too many clear conversions for this. What is the best way to figure what diff would fit underneath? Is there a kit available for the buget minded? My son does not get enough pay at the sweatshop to support my hobbies.
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Just wanted add the note: The tech tip apply's to the 46 and older truck. The car torque tube assy, is shorter and narrower than the AD truck assy. Now is the time to go with newer tranny, open drive line and rearend. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | In addition to that, the '49-'54 passenger differential is a different design, not interchangeable with the truck. It has more in common with the '55-'64 10 bolt passenger rear.
Bill Burmeister | | | | | Joined: May 2003 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 27 | Darn. Thanks for the info guys.
