3 members (NJC, HandyAndy, Oswald), 129 guests, and 3 robots.
Topics128,081
Posts1,055,955
Members48,430
#532015 04/25/2009 11:11 AM
Does anyone have a source for the rear window gaskets for a 58 Panel?
Mike
In loving Honor of
PFC Benjamin Gandalf Young
30 March 1988 - 27 May 2007
Sometime I wonder, Who you'd be today
www.BENS58.COM
Mike:
Steele Rubber Co. has excellent products. This link should take you right to the page. If not , use the search function on their home page. There is also a pdf installation guide.
http://secure.steelerubber.com/cgi-bin/v2.exe?yr=58&mk=CM&tp=ALL&pk=TN#81
Good luck with your project.
Mark
1958 GMC Suburban Carryall
Never accept a drink from a urologist!
also note Steele has the correct seals for the barn doors, even if not listed online - well worth getting
Sir Searchalot
Sir Searchalot
Steele, USA!!!! Before you install. put it in the sun then put tightly into opening, forcing rubber into corners and outward deep into pinch weld, cut some off but leave a few inches long and tape into place. You will have some rubber overhange because it's too long yet. Leave it there for a few days, checking that it is fully tucked in. then mark it exactly. I made a channeled holder out of wood (a jig). Put on the 3M wheatherstrip adhesive on the ends let sit per instructions on tube and bond. The channel jig keeps that butted secton straight and etc. Push together and hold with clampage of some sort, don't squeeze too hard, but make a tight joint. Once cured, install into window. If you don't want gaps and rubber that gradually pulls inward toward glass,, this is the way. Making it one piece before install this way looks really pro. I know you did not ask for this, but it's a good place for me to explain my method for consideration by others. Part of my jig was saw cut so that I cut the rubber straight with a sharp knife blade after into the jig, sort of like a miter box. Nothing is easy if you want it perfect. Bartamos.
