11 members (Woodcmiami, tonyt, DannyW, Bill Hanlon, walter74, gswbbc, baldeagle, lumbersawyer, Otto Skorzeny, JW51, 1 invisible),
86
Mod | | | Forums66 Topics128,040 Posts1,055,475 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 71 | I would do a search but I don't know what these are called. My 53 3100 has a wing shaped flap of metal attached to the upper door frame just above the vent window on both sides. They are attached with phillips head screws so I suspect they are aftermarket rain covers so you can crack the vent without water getting in the cab. I don't see them on pictures of otherwise stock trucks. Were they a factory option? | | | | | Joined: Nov 2008 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 104 | I think they came as original equipment, but I may be wrong. My truck has them. Where in Texas are you? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | My 52 also has them, I believe original eqpt. Tim | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | From 1951-55 there was a rain deflector at the forward top edge of the all doors (unfortunately, there is no photo in the Shop manual). You can almost see the deflector in this Master parts Book. Some people added a stainless steel non-GM air deflector. Any possibility you can post a link to a picture of what you are referring to? | | | | | Joined: Mar 2009 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 71 | FastEddie- I am in Plano-DFW area
Tclederman- Yes that illustration looks to be them. Mine were painted which makes sense for that year. | | |
