0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 17 Apprentice | | Apprentice Joined: Apr 2009 Posts: 17 | Hello fellow bolters I bought my 51 3/4 ton 6 years ago when my son was born. It's moved around with us alot and has gone through many stages of works in progress. I'm hoping to have it done in time for when he gets his driver ls  . anywho I came across a 66 c10 ten that gave me a donor motor to keep the looks of the bolt sorduv.... and have the advanages of a newer motor.. I'm still trying to get it to my shop to rebuild it..there is a first time for everthing.. since ive never rebuilt an engine i have lots of q's.. for for right now I'm having troble with my colum shifter my beloved three on the tree. Im in need of advice on adjusting it to keep it from getting stuck... any help would be great thanks. grin | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Welcome Grin. So your goal is to get it done in 10 years? That should be doable, your son can already hand you the wrenches. Any trouble I used to have with the linkage was usually right at the transmission. Often some slack or worn shifter connections. | | | | | Joined: Apr 2009 Posts: 17 Apprentice | | Apprentice Joined: Apr 2009 Posts: 17 | so if if disconect the linkage pins i should be able to shift it into neutral to move it with out using the clutch?
| | | | | Joined: Apr 2009 Posts: 17 Apprentice | | Apprentice Joined: Apr 2009 Posts: 17 | but when the linkage is diconected I still cant shift it from the arms on the trans
| | | | | Joined: Jun 2000 Posts: 738 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 738 | Hi Grin, Welcome to Stovebolt. Just go over to engine and drivetrain section and go to 'New Topic" and ask you questions over there. You should get your answer in no time. here is the link,,,,,, The Engine & Driveline Shop good luck | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | Hi,Grin! Good to see another Minnesotan on here! Welcome! | | | | | Joined: Oct 2008 Posts: 43 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 43 | Yeah! Welcome from another MN guy, Minneapolis here. | | |
