4 members (32Fordpuchoptop, 55shaker, TUTS 59, 1 invisible), 70 guests, and 0 robots.
Topics128,078
Posts1,055,940
Members48,430
#5313 10/06/2002 10:08 PM
I'm trying to determine the displacement of the engine in my 1955 3200... I took your advice and copied down the numbers on the block, but when I compaired it to the list I found off of this site it said it could be either a 235 or a 261. These are the numbers I got: the engine casting number says 3837004 with GM5T nearby; the serial # says 0532002T255S with a larger C at the end; finally, I found a number between the starter and the block and it said CGNV1 10J17 55 (I'm not sure if the C and G are correct though... I was having a hard time reading it). I didn't notice any captain's marks on the block, but I could have overlooked them. If anyone has any information or could point me in the right direction I would really appreciate it. Thanks!
Neil
1955 Chevy 3200
#5314 10/07/2002 3:27 AM
What is the casting number on the head and what is the oil line diameter and what is the thermostat diameter? If it has an '848' head chances are it's a 235.
Paint & Body Shop moderator
#5315 10/07/2002 4:27 AM
My list of block numbers shows 3837004 as a 55-57 235.
1946 1/2-Ton Chevy
#5316 10/07/2002 2:24 PM
Milhouse I too have a 3837004 block and mine is a 235. Captian bars would be on both sides of the block if you had a 261. One of the easier ways to tell a 261 from a 235 is the size of the hole for the oil lines to the filter and sending unit on the drivers side rear of the block. The 261 has 3/4" pipe fittings (very large). Otherwise for the 235 it will be 1/4" or 3/8" pipe threads
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#5317 10/07/2002 7:34 PM
Do the '54-'57 261s have the large holes for the oil-filter lines; or, are the larger holes only on the '58-'62 261s (that had full-flow oil filtration systems)?
For more information on 261s, check out Jim Carter's technical article on "The Forgotten 261 Six Cylinder" (it's not forgotten on this forum).
http://www.oldchevytrucks.com/cgi-bin/htmlos.cgi/001097.2.5428224320315357751
Tim
