4 members (Otto Skorzeny, tclederman, Rusty Heaps, baldeagle), 74 guests, and 8 robots.
Topics128,020
Posts1,055,345
Members48,419
#531184 04/22/2009 9:53 PM
Apprentice
Apprentice
Hello fellow bolters I bought my 51 3/4 ton 6 years ago when my son was born. It's moved around with us alot and has gone through many stages of works in progress. I'm hoping to have it done in time for when he gets his driver ls grin. anywho I came across a 66 c10 ten that gave me a donor motor to keep the looks of the bolt sorduv.... and have the advanages of a newer motor.. I'm still trying to get it to my shop to rebuild it..there is a first time for everthing.. since ive never rebuilt an engine i have lots of q's.. for for right now I'm having troble with my colum shifter my beloved three on the tree. Im in need of advice on adjusting it to keep it from getting stuck... any help would be great thanks.
grin
Leo Offline
Moderator
Moderator
Welcome Grin. So your goal is to get it done in 10 years? That should be doable, your son can already hand you the wrenches. Any trouble I used to have with the linkage was usually right at the transmission. Often some slack or worn shifter connections.
Leo #531206 04/22/2009 11:06 PM
Apprentice
Apprentice
so if if disconect the linkage pins i should be able to shift it into neutral to move it with out using the clutch?
Apprentice
Apprentice
but when the linkage is diconected I still cant shift it from the arms on the trans
Joy Offline
Hi Grin, Welcome to Stovebolt. Just go over to engine and drivetrain section and go to 'New Topic" and ask you questions over there. You should get your answer in no time. here is the link,,,,,, The Engine & Driveline Shop good luck
Joy #531597 04/24/2009 3:43 AM
Hi,Grin!
Good to see another Minnesotan on here! Welcome!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Rich'sToys #539804 05/21/2009 6:01 PM
Yeah! Welcome from another MN guy, Minneapolis here.
-Luke
"Pleasure in the job puts perfection in the work."
Story in The Gallery
Project pics on Photobucket
