3 members (Robert Crandall, 1955 1 Series, 1 invisible), 328 guests, and 6 robots.
Topics128,156
Posts1,057,021
Members48,460
can this seat be original equipment on a 65 c60 2ton.
http://s427.photobucket.com/albums/...view&current=partstrkteardown014.jpg
as i took this truck apart i noticed lots of parts that will work on my 63 c60 or am i just seeing things.
steering coulum,inner finders,steering box,lots of little things look the same to me.
this truck was hit hard on the passenger side one cab mount bolt was missing two of them were bent.
http://s427.photobucket.com/albums/.../?action=view&current=Picture159.jpg
if the parts wont work on my 63 then im gona have to build a 65 if they will work on my 63 im gona have a lot of parts left over for a 1965 c60 2ton.
http://s427.photobucket.com/albums/...view&current=partstrkteardown021.jpg
i took this truck apart for the parts and practice now im not so worried about taken my 63 apart i have a better idea of what to expect when i start.
http://s427.photobucket.com/albums/...view&current=partstrkteardown081.jpg
1963 Chevy C60 Apache Dump Truck
Stovebolt Gallery Page
Photobucket pictures
I can't speak about that seat, but I can tell you about parts interchange. Yes, a bunch of those parts off the '65 will work on your '63. The fenders, hood, and lots of other parts will fit on the '63. So, you have a bunch o' parts now! Of course, you could always fix up the '65 and have 2 C60's. Just sayin.... grin
1963 Chevy C20 Longbed Stepside
1978 Chevy K30 Custom Deluxe
pretty much the main difference is the windshield,cab,and doors,all related to the kneenocker wrap around windshield.60 to 63 for wrap around,64 to 66 for flat.The rest should fit!
65 Chev shorty
65 Chev longbox
65 Chev crewcab
65 Chev bus!
the cab and passenger side of the truck is wiped out.
drivers side door is rusted out at the bottom but the frame and undercarrige are in good shape i am thinking that i can start with this frame get it all ready for my 63 swap over and build my 63 any left over parts from the 65 il donate to who ever wants them when im done with it {that is if the frames are the same} i still have to mesure and check everthing out
I have sone some chev trucks & there are all kinds of diff seats.
There are what I call 1/3 driver seats only.
Some are 1/3 drivers seat & 2/3 passenger.
Some Pass are 1/3 to.
Some are bench seats, Its what ever the custemer wanted when it was bought. Or what the new oner put in there when they bought it used.
I have a IH truck with a chev suberben seat in it, No leg room sit streight up. Knees hit steering wheel.
I remember seats like that in new several cab & chassis we had in our shop at the time. So, yes...I'd say it is original.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
The only down side to swapping to the newer frame is the vin number stamped on the frame will be for a '65 not the '63...if that matters...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
im not gona do a frame swap now because the 65 has had 2 cuts and welded places on the frame with a 4ft peice added in plus a 18 inch peice added on the end over all length 252 inches
http://s427.photobucket.com/albums/...view&current=partstrkteardown110.jpg
iv taken all the parts off that i want for my 63 steering box, steering wheel, brake line junctions, hydrovac, shakels, radiator support, inner fenders, {just about everything}
after im done il offer up what parts are left to who ever wants them.
