1 members (Rusty Rod), 80 guests, and 2 robots.
Topics128,127
Posts1,056,680
Members48,452
Junior Member
Junior Member
My Uncle showed up with machined engine parts for a 235 chevy engine, Crank, Cam, Block, Heads, and then some. "It just needs to be put together", he says.
Well the Crank Cam and block is coverd in rust, no major damage from what I can tell. I can hone out the Block and the head is good.
Can these parts be used as is after wiping them down with an oily rag? What is a good way to clean the Crank and Cam? They have been already machined. I did not want to use emery cloth or sandpaper. What should I look for in damage to the crank and cam?
Know where I can get engine rebuild manuel on a 1960 - 70 6 cylinder engine?
Thanks for the Info?
My ND loadmaster engine is on her final climb.
You thought I drove a Ford! Where is my cresent wrench, I would like to adjust your thought pattern.
I used an engine once that had been machined & left for years w/o oil on the machined surfaces. It had fine surface rust but no pitting. I used a Scotchbrite pad & some diesel, worked fine, engine ran perectly. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Don't use sandpaper on journals. Find some crocous cloth. If they are rust pitted at all, take it to a machine shop, in fact, that's probably a pretty good idea, let them ck it out for you.
Go to one of the chevy vendors and get a 1960 shop manual. Chevy Duty, All American Classics, LMC trucks, Jim Carter. All these guys should have them. Priceless info. Getting one and reading it should be the first thing you do.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
yep scotch brite pad works on armetures to wont remove or hurt the metal
I would still have a machinist look over the parts to make sure. Bearing journals are something I want perfect on engines that I build.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
