6 members (tclederman, Gray_Ghost, Gdads51, Lightholder's Dad, Paul Mullen, 1 invisible), 184 guests, and 4 robots.
Topics128,077
Posts1,056,019
Members48,433
#530856 04/21/2009 10:16 PM
What flywheel application can I look to, to purchase and bolt to my 5.3L LM7? Seems they are all backed up by automatics. Can the 4.8L or 6.0L flywheels work? There are many manual applications for the engines.
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
cavebull,
I'm pretty sure ANY 1987 or later Chevy/GM V-8 flywheel made for the one piece rear seal will work! Try 'Vette or 1 ton work trucks.
Clutch will be the same form the '60s on.
Best wishes,
Les
Thanks Les,
Curious what I will be getting into if I go this route. I know the blocks are different but the bellhousings (assume)are the still the same. Always looking as possibles before I go gettin' dirty hands and bloody knuckles, and thats just pulling out the wallet!
Brett
cavebull
Do you know the LS1Tech.com forum? It specializes in the LS family of engines and there is huge knowledge available. I know of at least 2 different flywheels for these engines, but that is all I know!
'57 Chevy Suburban; '70 Chevy Impala.
Cool, I will give'em a look right now.
Brett
cavebull
From Jefferson Bryant's book, you can match an LS-based motor to an older transmission. Get the GM retrofit bellhousing which allows the LS motors to be bolted to Muncie, T-10, Saginaw, Richmond, TKO, Tremec T56-011. See Pace Performance who is a reseller. LS truck flywheel is used which is GM partno 12561680 12-inch clutch and pressue plate P/N RAM88744 and 6 pressure plate bolts P/N 12561465.
He also says McLeod and Advance Adapters offer aftermarket versions of the same thing.
Also, you may find some info here: http://www.ls1truck.com/forums/mechanical/14013-t-56-swap.html
Hope this helps.
R-Bo
1966 GMC 305V6 in the family
R-BO,
part numbers - that very cool.
Brett
cavebull
