1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | What flywheel application can I look to, to purchase and bolt to my 5.3L LM7? Seems they are all backed up by automatics. Can the 4.8L or 6.0L flywheels work? There are many manual applications for the engines.
Cavebull | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | cavebull,
I'm pretty sure ANY 1987 or later Chevy/GM V-8 flywheel made for the one piece rear seal will work! Try 'Vette or 1 ton work trucks. Clutch will be the same form the '60s on.
Best wishes,
Les | | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Thanks Les, Curious what I will be getting into if I go this route. I know the blocks are different but the bellhousings (assume)are the still the same. Always looking as possibles before I go gettin' dirty hands and bloody knuckles, and thats just pulling out the wallet!
Brett | | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Do you know the LS1Tech.com forum? It specializes in the LS family of engines and there is huge knowledge available. I know of at least 2 different flywheels for these engines, but that is all I know!
'57 Chevy Suburban; '70 Chevy Impala.
| | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | Cool, I will give'em a look right now. Brett | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | From Jefferson Bryant's book, you can match an LS-based motor to an older transmission. Get the GM retrofit bellhousing which allows the LS motors to be bolted to Muncie, T-10, Saginaw, Richmond, TKO, Tremec T56-011. See Pace Performance who is a reseller. LS truck flywheel is used which is GM partno 12561680 12-inch clutch and pressue plate P/N RAM88744 and 6 pressure plate bolts P/N 12561465. He also says McLeod and Advance Adapters offer aftermarket versions of the same thing. Also, you may find some info here: http://www.ls1truck.com/forums/mechanical/14013-t-56-swap.htmlHope this helps.
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Jul 2006 Posts: 451 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 451 | R-BO, part numbers - that very cool. Thanks, Brett
