11 members (KEVINSKI, Hotrod Lincoln, TUTS 59, Gdads51, Dusty53, Lonnie, klhansen, Geo55, Gray_Ghost, 2 invisible),
186
Mod | | | Forums66 Topics128,165 Posts1,056,992 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | Looking for a part number for a 55-59 V8 bell housing. Were they the same throughout those years? Thanks hb32
1955 Chevy 3100
| | | | | Joined: May 2003 Posts: 14 New Guy | | New Guy Joined: May 2003 Posts: 14 | Talked to good friend of mine tonight, said his first truck was a 55 3100. When he blew up the 235, he said he bought a bellhousing and bolted a 327 right up to the stock 3 on the tree. Can this be done, or is the liquid courage clouding his memory?
Brian 1955 (2nd) Chevrolet 3200 1999 Suburban (family truckster) 1966 Ford F100 (parts runner) | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | B Bri Could be done with any 55-59 v8 truck bellhousing or 60-67 V8 truck bellhousing or 63-68 6 cylinder truck bellhousing.
The rear of the engine would mount on the existing crossmember, just like the stock 6. Clutch and transmission would work just like stock. You would lose your floor starter, and you would have to figure out how to bolt the front of the engine down, but that has already been figured out for you. | | | | | Joined: May 2003 Posts: 14 New Guy | | New Guy Joined: May 2003 Posts: 14 | Thanks bigbadswingdaddy. Of course I will now ask again for HB32, anyone know the part numbers that will work for this?
Brian 1955 (2nd) Chevrolet 3200 1999 Suburban (family truckster) 1966 Ford F100 (parts runner) | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy hb32,there were 3 or 4 different part numbers for V8 bellhousings from 55-59 3716597 was the first, 3776887 was the last which superseded 3742055 and 3742053. The newer ones bigbadswingdaddy mentioned have a larger hole for the throwout arm, as the newer arms were formed, and the early ones were cast or forged, and the 60 - 62 bellhousings may have the throwout arm hole on the right side rather than the left, for a hydraulic clutch setup. On another matter I sent you a P.M. which you don't seem to have read yet, please read it and let me know, thanks. | | | | | Joined: Oct 2008 Posts: 121 Shop Shark | | Shop Shark Joined: Oct 2008 Posts: 121 | Thanks for the info and sorry for the slow reply on the pm as I am still trying to figure this place out. Just managed to slide the truck through aircare yesterday and now waiting on collector plates. Unfortunately, I am scheduled to work that day and would like to take a rain cheque.
1955 Chevy 3100
| | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | to answer your question, yes there are numerous different bell housings. mounts can be different too. make sure you can bolt up to your truck not jst the front of the housing, but the bolts to the actual truck
56 stepside 3/4 ton longbed
