| | | Forums66 Topics128,087 Posts1,056,107 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | Finally got everything working.New brake switch,new headlamp switch ! Now it appears that the running lights are brighter than the brake lights ? Is this normal or is there a fix.The running lights seem very bright and when the brakes are applied it get slightly brighter ? These are new repro. tail lights. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you probably have the wires reversed, the brake light should 'overwhelm' the tail light .... what happens with the turn signals? the signals activate the brake filament and need to be seen clearly
Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I second that motion that the wiring is crossed. You will probably find that the blinker is not visible. | | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | I'll check that.Report back. Thanks | | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | Wires reversed,problem solved ! Thanks guys. | | |
